1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway 2.0.5.0 released
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 19 Dec 2014 10:37:56 +0100
On 15/12/2014 18:10, Benjamin Franksen wrote:
Am Freitag, 12. Dezember 2014, 20:42:16 schrieb Ralph Lange:
Hi Freddie,
Note that for the gateway part, I published a fix release 2.0.5.1 on
Monday, which contains the same or equivalent fixes for everything you
have in your patch. Thanks, anyway - sorry that you had to go through
the same mess...
As for the caPutLog part, that's not me. I agree with Andrew that
removing the epicsShareAPI would be the way to go.  Are the maintainers
listening? Please?!
Hm, that would be me I guess. So is removing epicsShareApi the consensus or
not? If there are inconsistencies between .c and .h files in caPutLog I will
fix them in favor of whatever you think is more useful.
Yes, please remove the epicsShareAPI declaration.
This decoration (that affects the way arguments are passed from caller to function) should only be applied to functions that are intended to be called from other programming languages with possibly different parameter-passing conventions.
Thanks a lot,
~Ralph
CA Gateway 2.0.5.0 released Ralph Lange
RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Re: CA Gateway 2.0.5.0 released Ralph Lange
Re: CA Gateway 2.0.5.0 released Benjamin Franksen
Prev: Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Andrew Johnson
Next: Job openings at ESS Timo Korhonen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA Gateway 2.0.5.0 released Benjamin Franksen
Next: RE: connecting EPICS to a Beckhoff PLC [SEC=UNCLASSIFIED] LYNCH, Damien
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
