1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Serial port COM10: not work?
To: Eric Norum <[email protected]>, Mark Rivers <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Thu, 1 Oct 2015 06:46:17 +0200
I propose the following:
-If the device name passed to drvAsynSerialPortConfigure starts with  ‘\’
 then assume the user has used a device name, and use it directly.
-If the device name does not begin with ‘\’ then prepend “\\.\”.
That sounds ideal.
Minor nit and suggestion for improvement to avoid futere suprises:
If the device name does not start with
'\\.\', prepend '\\.\'
Written in C-language: "\\\\.\\"
Serial port COM10: not work? Heesterman, Peter J
Re: Serial port COM10: not work? Jack
RE: Serial port COM10: not work? Mark Rivers
Re: Serial port COM10: not work? Eric Norum
Prev: RE: New sequencer releases Mark Rivers
Next: RE: Serial port COM10: not work? Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Serial port COM10: not work? Eric Norum
