1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Serial port COM10: not work?
To: "'Mark Rivers'" <[email protected]>, "'Eric Norum'" <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Thu, 1 Oct 2015 11:15:38 +0000
Hi Mark,
Just a separate suggestion, while we’re on the subject of Windows serial port naming.
I wondered if it might be appropriate to provide ‘translation’ from /dev/ttyS<n> to \\.\COM<n+1>,  in order to hide the operating system dependency?
Peter.
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 30 September 2015 18:31
To: 'Eric Norum'
Cc: EPICS Tech-Talk ([email protected])
The code in question is in the Windows-specific driver file (drvAsynSerialPortWin32.c), so it is already Windows-specific.  We are not adding OS-specific code to a generic driver.
I don’t like users having to put 6 backslash characters into the device name, where everywhere else in Windows they just say COM10.
I agree with Peter’s suggestion that we don’t need a special case for COM1-COM9.
I propose the following:
-          If the device name passed to drvAsynSerialPortConfigure starts with  ‘\’  then assume the user has used a device name, and use it directly.
-          If the device name does not begin with ‘\’ then prepend “\\.\”.
Sent: Wednesday, September 30, 2015 11:14 AM
To: Mark Rivers
Subject: Re: Serial port COM10: not work?
I’m not convinced that burying windows-specific code like that into the configure command is a good idea.
What’s so hard about just noting in the documentation that COM ports above 9 require special naming — and since the IOC shell treats backslashes separately:
            drvAsynSerialPortConfigure(“L10”, “\\\\.\\COM10”, ……..)
On Sep 30, 2015, at 5:24 AM, Mark Rivers <[email protected]> wrote:
That may depend on which version of asyn you are using.  The upcoming R4-27 release contains the following in the release notes:
Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie      Akeroyd for this fix.
If you are running the master branch from github you already have this fix.  If not then I think you can work around the problem by using the full path name to the port when you open it, i.e.
\\.\COM10.
Eric Norum
[email protected]
RE: Serial port COM10: not work? Mark Rivers
Serial port COM10: not work? Heesterman, Peter J
Re: Serial port COM10: not work? Jack
Re: Serial port COM10: not work? Eric Norum
Prev: Re: Serial port COM10: not work? Torsten Bögershausen
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Serial port COM10: not work? Mark Rivers
