1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: EpicsQt compile problems
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Mar 2016 11:30:55 +0000
Hi Rory
I can’t see any particular problem with your setup. We have tried to ensure EpicsQt continues to build over a range of version of Qt and compilers and your setup is not exceptional. While we don’t confirm that the latest of everything will work all the time, I have recently confirmed the following setup builds and runs with the latest trunk source based on epicsQt 3.2.5. (Although there are warnings regarding the use of some deprecated Qt include files which have moved in Qt5.5 which will be removed shortly.)
- Window8 64 bit
- Qt 5.5.1 MinGW 32 bit
- Qt Creator 3.6.0 Based on Qt 5.5.1 (MSVC 2013, 32 bit)
- MinGW 4.9.2   32 bit
- QWT 6.1 built with MinGW 4.9.2   32 bit
- EPICS 3.15.3 built with MinGW 4.9.2 and Strawberry Perl 5.22.1.2-64bit
This set up is not a long way from your own.
Changes for Qt5 were introduced around epcisQt version 2.8, changes for Qt5.2 were released in 3.2.3 changes for Qt5.4 were released in epicsQt 3.2.4. If epicsQt3.1.0 compiles Ok, the you should be good regarding the Qt version.
By the way, to avoid some mingw environment errors you can include the following in examplePlugin.pro and framework.pro which may avoid the need to comment out Timespec. (This ‘defines’ is already there, just commented out)
  DEFINES += _MINGW=TRUE
Also – a long shot - QtDesigner won’t let you mix debug and release plugins, so unless all plugins are debug, you can’t run a debug version of QEPlugin.dll, but I recall it kicks back with a very specific message about this though. Not the "not valid win 32” message you are dealing with.
Rather than try to use it in Designer as a plugin, have you tried running QEGui, or one of the sample applications (QEMonitor, QEWidgetDisplay) in epicsQt which loads QEPlugin.dll as a dll rather than a Qt plugin?
I hope some of this helps. Let me know if I should do some more digging.
Regards
Andrew
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Friday, 4 March 2016 08:29
To: [email protected]
Subject: EpicsQt compile problems
Hi, I am having some major problems trying to compile EpicsQt source files to make custom plugins
My setup is a Windows 64 bit machine and I compile in 32 bits but I think the problem is using Qt5 which is 32 bit and telling me “%1 this is not a valid win32 plugin”
Setup:
64Bit machine, Windows7
Qt5
For Visual Studio I used the C++ libs:
VC 2012 and VC 2015. I ended up only using VC2012 libs to get as close to the Qt4 install as possible
Mingw32 bit
Strawberry Perl 32 bit
All compiled on the command line.
The version of EpicsQt is 3.1.0 simply because I found a working windows version of epicsqt on Sourceforge that I could trial and assumed that if the EpicsQt team could get that working so could I.  I have made some of my own libraries under this system but I get a strange “not valid win 32” error when try to open the QEPlugin.dll in designer 5.5. I am wondering if I am using something that is too new?
I compiled Epics Base and epicsqt with the win-x86-ming32. The only change I made was to comment out Timespec for EPICS base to get this to work with Mingw32 but base works and caget opens. VC2012 is also set to be 32 bits in this compile.
Now for EpicsQt:
3.1.0 compiles just fine. I used a program called “depends” to check QEPlugin.dll . It shares to the exact same x64 system libs that the working demo version uses and is an x32 lib like the working version. So, seeing as I have used 32bits everywhere, any idea why Qt5 should throw that error? Will EpicsQt not build for Qt5? I’m hoping that one of the Qt’ers out there has used a similar setup (Qt5, Visual Studio 2013 or 2015). I tried to install Qt4 in desperation but it is telling me that Mingw32 Is too new and may cause errors. I am wondering what should be the next step forward, as the Qt designer “not a valid win32 ” error is not much to go on.
Rory
Rory Clarke
Electrical and Controls Systems Group
Daresbury Laboratory
Keckwick Lane
Warrington
Cheshire
WA4 4AD
E: [email protected]
T: 01925 60 Ext. 3777
RE: EpicsQt compile problems rory.clarke
Prev: Re: mrfioc2 error at uTCA platform Konrad, Martin
Next: Request for help on CSS Anindya Roy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: EpicsQt compile problems rory.clarke
Next: RE: EpicsQt compile problems rory.clarke
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
