1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unable to tunnel CSS CA through ssh tunnels
To: Jon Brinkmann <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Sun, 29 May 2016 15:07:38 +0200
Hi Jon,
On 29/05/2016 04:41, Jon Brinkmann wrote:
Several years ago Andre Charbonneau described how to tunnel CA
through ssh tunnels:
http://www.aps.anl.gov/epics/tech-talk/2013/msg00142.php
The method works well for EPICS base and extensions that use the EPICS
libraries.  It doesn't work with CSS because CSS doesn't use those libraries.
I think CSS uses Java CA.  I've searched the CSS documentation and the
Internet in vain.  Can it be done in the current version of CSS (4.1.1)?
If so, how?  If not, would you consider adding that functionality?
Alas, this feature has not been added to Java CA.
Basically, you have three options:
  1. Add it to Java CA. You probably want to coordinate with the upstream authors on the best way to do that.
  2. Pay someone to add it to Java CA. There are consulting firms that would be in the position to help. Osprey DCS and Cosylab are among those.
  3. Use a workaround. Either a specific UDP solution (as the one one Till pointed out), or an EPICS CA Gateway on your client side box. The Gateway would use on its client side a setup similar to the one described in the Tech-Talk message you refer to (but with a different local port), and set its server side to localhost:5064.
    CS-Studio instances (and all other clients) would then use that Gateway on localhost to get through the tunnel.
Hope this helps,
~Ralph
Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Re: Dynamically refresh CSS BOY runtime OPI Kasemir, Kay
Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
Prev: Re: archiver appliance vs. data browser Kasemir, Kay
Next: Re: EPICS Base 3.15.4 released Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
Next: AQUENOS:s7nodave Driver Experience Nick Levchenko
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
