Jon.
Adding SOCKS support to caj is an almost trivial patch. With that you
can tunnel CSS just fine (did you see the respective paragraphs?
http://slac.stanford.edu/~strauman/epics/caxy/documentation/caxy.html#section_7_1_1_1
HTH
- Till
On 06/01/2016 04:06 AM, Jon Brinkmann wrote:
Till,
I've looked over your "caxy" package. Nice job!
Also see http://www.delegate.org/delegate/, which is a very nice "Swiss
Army Knife" of tunnelling and port forwarding using SOCKS. It does both TCP
and UDP forwarding. The documentation is a fair translation from Japanese,
so takes a little bit of work to understand.
Less versatile is https://github.com/apenwarr/sshuttle, which uses ssh
forwarding.
Unfortunately, I was hoping for a bundled solution, so I wouldn't have to put
our users through any more work than necessary. It's to bad that CSS is not
ssh tunnelling compatible while EPICS base, and the clients that use it, are.
- Jon
On Sun, May 29, 2016 at 04:39:59PM +0900, Till Straumann wrote:
Try this. I had it working for css.
http://www.slac.stanford.edu/~strauman/epics/caxy/
HTH
- Till
On 05/29/2016 11:41 AM, Jon Brinkmann wrote:
Kay,
Several years ago Andre Charbonneau described how to tunnel CA
through ssh tunnels:
http://www.aps.anl.gov/epics/tech-talk/2013/msg00142.php
The method works well for EPICS base and extensions that use the EPICS
libraries. It doesn't work with CSS because CSS doesn't use those libraries.
I think CSS uses Java CA. I've searched the CSS documentation and the
Internet in vain. Can it be done in the current version of CSS (4.1.1)?
If so, how? If not, would you consider adding that functionality?
Jon
Dr. Jon Brinkmann, Factotum Apache Point Observatory
Software Engineer 2001 Apache Point Road
Instrument Scientist P.O. Box 59
E-mail: [email protected] Sunspot, NM 88349-0059
URL: http://www.apo.nmsu.edu/brinkmann/ Tel: 575-437-6822
- Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
- RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
- RE: Dynamically refresh CSS BOY runtime OPI will.rogers
- Re: Dynamically refresh CSS BOY runtime OPI Kasemir, Kay
- Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
- Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
- Re: Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
Control System Engineer (ESS, Sweden) David Brodrick
<2016>
2025
Re: Unable to tunnel CSS CA through ssh tunnels Ralph Lange
<2016>
2025
