Till,
I've looked over your "caxy" package. Nice job!
Also see http://www.delegate.org/delegate/, which is a very nice "Swiss
Army Knife" of tunnelling and port forwarding using SOCKS. It does both TCP
and UDP forwarding. The documentation is a fair translation from Japanese,
so takes a little bit of work to understand.
Less versatile is https://github.com/apenwarr/sshuttle, which uses ssh
forwarding.
Unfortunately, I was hoping for a bundled solution, so I wouldn't have to put
our users through any more work than necessary. It's to bad that CSS is not
ssh tunnelling compatible while EPICS base, and the clients that use it, are.
- Jon
On Sun, May 29, 2016 at 04:39:59PM +0900, Till Straumann wrote:
> Try this. I had it working for css.
> http://www.slac.stanford.edu/~strauman/epics/caxy/
> HTH
> - Till
> On 05/29/2016 11:41 AM, Jon Brinkmann wrote:
> >Kay,
> >Several years ago Andre Charbonneau described how to tunnel CA
> >through ssh tunnels:
> >http://www.aps.anl.gov/epics/tech-talk/2013/msg00142.php
> >The method works well for EPICS base and extensions that use the EPICS
> >libraries. It doesn't work with CSS because CSS doesn't use those libraries.
> >I think CSS uses Java CA. I've searched the CSS documentation and the
> >Internet in vain. Can it be done in the current version of CSS (4.1.1)?
> >If so, how? If not, would you consider adding that functionality?
> >Jon
> >Dr. Jon Brinkmann, Factotum Apache Point Observatory
> >Software Engineer 2001 Apache Point Road
> >Instrument Scientist P.O. Box 59
> >E-mail: [email protected] Sunspot, NM 88349-0059
> >URL: http://www.apo.nmsu.edu/brinkmann/ Tel: 575-437-6822
- Re: Unable to tunnel CSS CA through ssh tunnels Till Straumann
- Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
- RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
- RE: Dynamically refresh CSS BOY runtime OPI will.rogers
- Re: Dynamically refresh CSS BOY runtime OPI Kasemir, Kay
- Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
calculating macros Dirk Zimoch
<2016>
2025
<2016>
2025
