Hi Mark,
On 01/19/2017 08:05 AM, Mark Rivers wrote:
>> Are you sure that your CentOS 7 box exports the file system also as NFS 2?
> That is probably the problem. Do you know how to enable that?
I got this from our IT group for RHEL-7:
> https://access.redhat.com/solutions/1593263
> * Edit /etc/sysconfig/nfs, and change the RPCNFSDARGS to the following
> (uncommenting if necessary):
> RPCNFSDARGS="-V 2"
> * restart the nfs-config.service
> # systemctl restart nfs-config.service
> * Restart the nfs-server.service
> # systemctl restart nfs-server.service
> You can then verify that nfs v2 is enabled with the following:
> # rpcinfo -l localhost 100003 2
> or
> # rpcinfo -p | grep -w nfs
> Arista Thurman III
> Principal Computer Engineer
> Information Technology Group
> Advanced Photon Source
> Argonne National Laboratory
Note that if you're using my -asd8 VxWorks 5.5.2 OS images they also
support NFSv3, whereas for the -asd7 images I had disabled NFSv3.
- Andrew
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
RE: CA server bind failure on Windows freddie.akeroyd
<2017>
2025
2026
<2017>
2025
2026
