Subject: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Jan 2017 18:00:55 +0000
Hi Andrew,
Good news and bad news.
The good news is that by booting vx55 with -asd8 I can mount NFS on our Centos7 server without changing its NFS configuration.
The bad news is that by changing from -asd7 to -asd8 we introduce the uninitialized interrupt messages from our Analogic DVX-2503 cards.
These messages do not happen on:
MVME5100 with VxWorks 5.5 or 6.9.4
MVME2100 with VxWorks 5.5 -asd7
They do occur with:
MVME2100 with VxWorks 6.9.4 or 5.5 -asd8.
Is anyone else using Analogic DVX-2503 cards with VxWorks?  If so, what version of VxWorks?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, January 19, 2017 11:36 AM
To: [email protected]
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
Calling all RTEMS developers (Till, Eric, Michael, Heinz): Given the
statement below from Red Hat, are there any plans in the works to
support NFSv3 or later on RTEMS, or some other modern network filesystem
protocol?
On 01/19/2017 10:42 AM, Torsten Bögershausen wrote:
> But I am afraid that NFS 2 is no longer supported:
> <https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html-single/Storage_Administration_Guide/index.html#ch-nfs>
The RTEMS NFSv2 client does talk to our RHEL-7.3 server with the
configuration change I posted for Mark, but the VxWorks 5.4.2 NFS client
broke somewhere between the RHEL-7.2 and 7.3 servers. VxWorks 5.5 has an
NFSv3 client (which is buggy, make sure you get all the available
patches) that works OK against a RHEL-7.3 server.
The APS now only has *2* production IOCs left running on EPICS 3.13.10,
having upgraded the others to Base-3.14.12 and VxWorks 5.5 or 6.9. This
solved the NFSv2 issue for VxWorks, but our RTEMS-4.9.2 and 4.10.2
systems are still stuck with NFSv2...
- Andrew
RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
Prev: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
Next: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Heinz Junkes
Next: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
