1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 21 Feb 2017 10:42:45 +0000
I think  get_precision()  expects a  long*  for the precision but the variable passed is declared   int   in getFloatString() and getDoubleString(). In theory this could cause a crash on 64 bit linux as int and long are different sizes, but It wouldn’t explain the 32bit crash though as int and long are the same size on that architecture…
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: 21 February 2017 08:54
To: Carsten Winkler
Cc: EPICS Tech Talk
Subject: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit
Hi Carsten,
The default value for precision used when you comment out the lines you mention is 6.
Can you achieve the same (i.e. avoid segfaults) by setting PREC to 6 in your database?
If yes: which PREC values cause segfaults?
Cheers,
~Ralph
On Tue, Feb 21, 2017 at 9:15 AM, Carsten Winkler <[email protected]> wrote:
I forgot to give you the used db entry. Here it is:
record(waveform, "caLab:waveString")
    field(DESC, "String waveform record")
    field(NELM, 48)
    field(FTVL, "STRING")
    field (PINI, "YES")
    field (PREC, 3)
Am 20.02.2017 um 15:40 schrieb Carsten Winkler:
> Hi there,
> I always run into a  "Segmentation fault" in function "putFloatString" |
> "putDoubleString" of BASE/src/db/dbConvert.c
> When I comment out following lines (call of get_precision) everything is
> working again:
> 3947
> 3948
> 4157
> 4158
> Test system
> Ubunu 16.04 (64 bit)
> EPICS BASE 3.14.12.6 (64 bit)
> To check the error, I used this code:
> test.cpp
> #include <malloc.h>
> #include <cadef.h>
> //#define DOUBLE
> using namespace std;
> int main() {
>     chid chanID;
>     int iNumber = 1;
>     int timeout = 0;
>     void *pValue = 0x0;
>     ca_context_create(ca_enable_preemptive_callback);
> #if defined DOUBLE
>     pValue = (double*)malloc(iNumber*sizeof(double));
>     for(int i=0; i<iNumber; i++) {
>         ((double*)pValue)[i] = (double)((1+i)*3.1415926535897);
> #else
>     pValue = (float*)malloc(iNumber*sizeof(float));
>         ((float*)pValue)[i] = (float)((1+i)*3.1415926535897);
> #endif
>     ca_create_channel("caLab:waveString", 0, 0, 50, &chanID);
>     timeout = 3000;
>     while(ca_state(chanID) != cs_conn && timeout--) {
>         epicsThreadSleep(.001);
> #if defined DOUBLE
>     ca_array_put(DBR_DOUBLE, 1, chanID, pValue);
> #else
>     ca_array_put(DBR_FLOAT, 1, chanID, pValue);
> #endif
>     ca_context_destroy();
>     free(pValue);
>     return 0;
> g++ -I/usr/local/epics/base-3.14.12.6/include/os/Linux
> -I/usr/local/epics/base-3.14.12.6/include -O0 -g3 -Wall -c
> -fmessage-length=0 -MMD -MP -MF"test.d" -MT"test.d" -o "test.o" "test.cpp"
> g++ -L/usr/local/epics/base-3.14.12.6/lib/linux-x86_64 -o "test"
> test.o   -lCom -lca
> Any advice to solve this issue?
> Best regards
> Carsten Winkler
> PS Same problem in 32 bit systems
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Postadresse:
D-14109 Berlin
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Benjamin Franksen
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Ralph Lange
Prev: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Ralph Lange
Next: Re: IOC Connecting Problem Pilkyu Jung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Benjamin Franksen
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
