Hi Pilkyu,
in your screenshot it seems your IOC does not know the commands
`drvAsynIPPortConfigure` or `asynSetTraceIOMask`.
There is also an error about setting the DTYP of a record to
stream is not possible.
So I guess, the dbd file of your IOC is missing the definitions
from asyn and steam.
When creating your IOC, did you include the dbd files of these
modules?
The file oscApp/src/Makefile should contain something like
osc_DBD += asyn.dbd drvAsynIPPort.dbd stream.dbd
Also check, if the libraries are correctly included in this
file. There should be a line like
osc_LIBS += asyn stream
I hope this helps you!
Best regards,
Florian
On 02/16/2017 07:29 AM, Pilkyu Jung
wrote:
Hi all,
First of
all, I am trying to connect from a oscilloscope which name is
Agilent Technologies DSO-X 3052A (500 MHz 4 GSa/s) to IOC.
As you
can see in the manual(http://literature.cdn.keysight.com/litweb/pdf/75019-97073.pdf
http://www.keysight.com/upload/cmc_upload/All/3000_series_prog_guide.pdf),
this
oscilloscope support a few ways (e.g. the IO Library, Telnet
Sockets, and using Browser Web Control) for sending SCPI.
However,
When I connect to IOC, I got a problem. Until now, I just
connected only adjust IP address in st.cmd.
Like
this,
drvAsynIPPortConfigure("P1",169.254.90.3:5025,0,0,0)
When I
connect by telnet, it is done successfully (please check the
Screenshot...image file).
I don't
know why this device can't be connected to IOC in this case.
Definitely I am done with this way before, but now I can't.
Here is my question,
1.
Normally, when you connect from device to IOC, what kind of
method use?
2. In my
case, How can I connect to IOC?
Best
Pilkyu
Jung
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz |
| Sektion SPECF |
| Staudinger Weg 18 |
| D-55128 Mainz |
| Office: 03-149 |
| Phone: (+49)6131 / 39-29655 |
