1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
To: 'Pawel Plewinski' <[email protected]>
Date: Tue, 11 Apr 2017 20:01:34 +0000
That is strange.  I run many waveform records at 10Hz or greater on VME system which are not fast CPUs at all.  What kind of CPU and what operating system is this?  What does your OS report for the CPU usage when you are running the IOC and the driver is sleeping for 0.5 seconds?
Are your waveform records forward linked to any other records which could be slowing things down?
What value are you using for EPICS_CA_MAX_ARRAY_BYTES?
-----Original Message-----
Sent: Tuesday, April 11, 2017 2:55 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
> When you say "lower than 1 second" do you mean the time between
> callbacks in your driver is less than 1 second, i.e. the usleep()
> value is less than 1000000?
Exactly, value below 1000000 (well, actually I can get down to 600000
without warnings) in usleep results in warnings. Maybe it's a matter of
speed, the machine that runs the IOC (and only the IOC, CSS is running
on a separate computer) is not the fastest one, but our Qt application
for this device is able to achieve update rate of ~100 ms at the same
time drawing plot, so I think period in the range of 100-150 ms should
be achievable here.
Now when I added asynSetTraceMask for the "missing" channels 1-3 now it
reports this warning for all variables.
Kind regards,
Paweł
W dniu 2017-04-11 21:18, Mark Rivers napisał(a):
> The record definition and dbpr output looks OK to me.
> In your original post you said:
>> The driver works, however if the update rate is lower than 1 second,
>> strange warning appears in the console at the time of every refresh
>> (and  that's only for one of 4 channels), namely:
>> 2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
>> devAsynFloat64Array::interruptCallbackInput
>> \000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
> Is the output coming because you have enabled some asynTrace?
>> devAsynFloat64Array::processCommon, warning, multiple interrupt
> Are you saying that this warning message only happens on the first
> waveform record, not on all of them?  That message is printed with
> this code in devAsynXXXArray.h:
>             if (pPvt->gotValue) {
>                 asynPrint(pPvt->pasynUser, ASYN_TRACE_WARNING,
>                     "%s %s::processCommon, "
>                     "warning: multiple interrupt callbacks between
> processing\n",                  \
>                      pr->name, driverName);
> Note that it is printed with the ASYN_TRACE_WARNING mask.  How have
> you called asynSetTraceMask in your startup script?  Is it possible
> you set it like this?
> asynSetTraceMask(testAPD, 0, 255)
> If so that would explain why you are only seeing the messages for the
> first waveform record.  The asynTrace is specific to the asyn address,
> and this only enables asynTrace on address 0.  To see the messages
> from all 4 waveform records you can do this:
> asynSetTraceMask(testAPD, -1, 255)
> or this
> asynSetTraceMask(testAPD, 1, 255)
> asynSetTraceMask(testAPD, 2, 255)
> asynSetTraceMask(testAPD, 3, 255)
> This would not explain why you are getting the messages in the first
> place, but it would explain why you are only seeing them for the first
> waveform record.
> Mark
> From: Paweł Plewiński [mailto:[email protected]]
> Sent: Tuesday, April 11, 2017 1:55 PM
> To: Mark Rivers
> Hi Mark,
> thanks for quick answer. Actually I forgot to post the record, but it
> had SCAN set to I/O INTR, similarly to the example project. Here's the
> record definition:
> record(waveform, "PIEZO:OSC-CH$(CHANNEL)-WAVEFORM")
>      field(DTYP, "asynFloat64ArrayIn")
>      field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))OSC_WAVEFORM")
>      field(FTVL, "DOUBLE")
>      field(NELM, "$(NPOINTS)")
>      field(LOPR, "0")
>      field(HOPR, "10")
>      field(SCAN, "I/O Intr")
> As for the commands you asked for, the results are, respectively:
> ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
> ASP: (nil)          BKPT: 00            BPTR: 0xbcb3e0      BUSY: 0
> DESC:               DISA: 0             DISP: 0             DISS:
> NO_ALARM
> DISV: 1             DPVT: 0xc05690      DSET: 0x7f2dbdcea9a0
> DTYP: asynFloat64ArrayIn                EGU:                EVNT: 0
> FLNK:CONSTANT 0     FTVL: DOUBLE        HASH: 0             HOPR: 10
> INP:INST_IO @asyn(testAPD,0,1)OSC_WAVEFORM                  LCNT: 0
> LOPR: 0             LSET: 0xc07f40
> MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> MLOK: b0 b3 bc 00 00 00 00 00           MPST: Always
> NAME: PIEZO:OSC-CH0-WAVEFORM            NELM: 1000          NORD: 1000
> NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0             PHAS: 0
> PINI: NO            PPN: (nil)          PPNR: (nil)         PREC: 0
> PRIO: LOW           PROC: 0             PUTF: 0             RARM: 0
> RDES: 0xb86470      RPRO: 0             RSET: 0x7f2dbda73340
> SCAN: I/O Intr      SDIS:CONSTANT       SEVR: NO_ALARM
> SIML:CONSTANT
> SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT       SPVT:
> 0xc135e0
> STAT: NO_ALARM      TIME: 2017-04-11 20:53:12.153366126     TPRO: 0
> TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: (nil)
> ASP: (nil)          BKPT: 00            BPTR: 0xbcd3a0      BUSY: 0
> NO_ALARM
> DISV: 1             DPVT: 0xc05be0      DSET: 0x7f2dbdcea9a0
> INP:INST_IO @asyn(testAPD,1,1)OSC_WAVEFORM                  LCNT: 0
> LOPR: 0             LSET: 0xc07f60
> MLOK: 70 d3 bc 00 00 00 00 00           MPST: Always
> NAME: PIEZO:OSC-CH1-WAVEFORM            NELM: 1000          NORD: 1000
> SIML:CONSTANT
> 0xc138f0
> STAT: NO_ALARM      TIME: 2017-04-11 20:53:29.910249080     TPRO: 0
> ASP: (nil)          BKPT: 00            BPTR: 0xbcf360      BUSY: 0
> NO_ALARM
> DISV: 1             DPVT: 0xc060e0      DSET: 0x7f2dbdcea9a0
> INP:INST_IO @asyn(testAPD,2,1)OSC_WAVEFORM                  LCNT: 0
> LOPR: 0             LSET: 0xc07f80
> MLOK: 30 f3 bc 00 00 00 00 00           MPST: Always
> NAME: PIEZO:OSC-CH2-WAVEFORM            NELM: 1000          NORD: 1000
> SIML:CONSTANT
> 0xc13c00
> STAT: NO_ALARM      TIME: 2017-04-11 20:54:17.907769453     TPRO: 0
> ASP: (nil)          BKPT: 00            BPTR: 0xa7b540      BUSY: 0
> NO_ALARM
> DISV: 1             DPVT: 0xab0810      DSET: 0x7efec944b9a0
> INP:INST_IO @asyn(testAPD,3,1)OSC_WAVEFORM                  LCNT: 0
> LOPR: 0             LSET: 0xab21d0
> MLOK: 10 b5 a7 00 00 00 00 00           MPST: Always
> NAME: PIEZO:OSC-CH3-WAVEFORM            NELM: 1000          NORD: 1000
> RDES: 0xa30650      RPRO: 0             RSET: 0x7efec91d4340
> SIML:CONSTANT
> 0xabe140
> STAT: NO_ALARM      TIME: 2017-04-11 20:52:33.970326348     TPRO: 0
> Best regards,
> Paweł
> W dniu 2017-04-11 18:24, Mark Rivers napisał(a):
>> Hi Pawel,
>> What is the SCAN field of your waveform record?  I suspect it is
>> probably periodic ("1 second", etc.).  For this application you should
>> set it to SCAN="I/O Intr".  Then the waveform record will process each
>> time your driver does a callback to device support.  If the record is
>> periodically processing at 1 second and your driver is doing callbacks
>> faster than 1 Hz then you will see the error you report.
>> Mark
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of Pawel Plewinski
>> Sent: Tuesday, April 11, 2017 8:49 AM
>> To: [email protected]
>> Subject: [AsynPortDriver] "Multiple interrupt callbacks between
>> Hi,
>> I've recently written asyn-based device support for a custom device
>> communicating over PCIe. One of its functions is to periodically
>> retrieve 4 waveforms from 4 channels, which is done in a separate
>> thread, from which the callback function is called to notify asyn
>> about
>> change. I heavily based the code on the AsynPortDriver example.
>> (and
>> The parameters passed to the top level constructor are
>>     : asynPortDriver(portName,
>>                      4, /* maxAddr */
>>                      (int)NUM_SCOPE_PARAMS,
>>                      asynInt32Mask | asynFloat64Mask |
>> asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface
>> mask
>> asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
>>                      ASYN_MULTIDEVICE, /* asynFlags.  This driver does
>> not block and it is not multi-device, so flag is 0 */
>>                      1, /* Autoconnect */
>>                      0, /* Default priority */
>>                      0) /* Default stack size*/
>> The readback thread code:
>> void piezoPortDriver::readbackTask(void)
>>     while (1) {
>>             bool stopped = false;
>>             lock();
>>             auto new_data = osc->fetch_data(vtim, vdat);
>>             unlock();
>>             if (!stopped)
>>                 lock();
>>                 this->osc_update_trigger();
>>                 unlock();
>>          callParamCallbacks();
>>          for (int i = 0; i < 4; i++){
>>            doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
>> P_OscWaveform, i);
>>          usleep(100000);
>> The fetch_data method reads four 1000-element double vectors from
>> PCIe.
>> Could you give me some suggestions what may be wrong?
>> Regards,
>> Paweł Plewiński
>> Department of Microelectronics and Computer Science
>> Lodz University of Technology
Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
Prev: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Next: Writing Area Detector Monitor Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
