Subject: Re: caRepeater: Syntax error: ")" unexpected
To: nb <[email protected]>
Date: Wed, 17 May 2017 15:48:38 +0000
For epics base on linux-arm neither is required.
For pcaspy the dependency is there to be compatible linux-x86.
> On 17 May 2017, at 17:14, nb <[email protected]> wrote:
>> On 17.05.2017 17:37, Wang Xiaoqiang wrote:
>> Instead of cross-compiling, you can compile epics base on RPi as well.
> I ran make again and it compiled successfully in couple minutes. The only thing that changed in the system is that I installed libreadline-dev and swig (those were required to build pcaspy).
> Is any of those required for the EPICS base? I didn't see it in the dependencies.
> Kind regards,
> Nick
caRepeater: Syntax error: ")" unexpected nb
Re: caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected nb
Next: Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
