Subject: Re: caRepeater: Syntax error: ")" unexpected
To: Wang Xiaoqiang <[email protected]>, [email protected]
Date: Wed, 17 May 2017 18:14:25 +0300
On 17.05.2017 17:37, Wang Xiaoqiang wrote:
Instead of cross-compiling, you can compile epics base on RPi as well.
I ran make again and it compiled successfully in couple minutes. The only thing that changed in the system is that I installed libreadline-dev and swig (those were required to build pcaspy).
Is any of those required for the EPICS base? I didn't see it in the dependencies.
Kind regards,
Nick
Re: caRepeater: Syntax error: ")" unexpected Wang Xiaoqiang (PSI)
Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Re: caRepeater: Syntax error: ")" unexpected Andrew Johnson
caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Next: Re: caRepeater: Syntax error: ")" unexpected Wang Xiaoqiang (PSI)
