Subject: Re: caRepeater: Syntax error: ")" unexpected
To: <[email protected]>
Date: Wed, 17 May 2017 11:11:52 -0500
On 05/17/2017 10:14 AM, nb wrote:
> On 17.05.2017 17:37, Wang Xiaoqiang wrote:
>> Instead of cross-compiling, you can compile epics base on RPi as well.
> I ran make again and it compiled successfully in couple minutes. The
> only thing that changed in the system is that I installed
> libreadline-dev and swig (those were required to build pcaspy).
> Is any of those required for the EPICS base? I didn't see it in the
> dependencies.
libreadline-dev is optional. The default configuration of Base for the
linux-arm target assumes that it is not present, but if you have it you
can edit your base/configure/os/CONFIG_SITE.Common.linux-arm and adjust
the setting of COMMANDLINE_LIBRARY in there as appropriate. You will
have to do a 'make rebuild' inside src/libCom for that configuration
change to take effect.
swig it not used by Base.
- Andrew
caRepeater: Syntax error: ")" unexpected nb
Re: caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Next: Re: Archiver appliance showing DESC field on pv details page Shankar, Murali
