Subject: |
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] |
"J. Lewis Muir" <[email protected]> |
To: |
Mark Engbretson <[email protected]> |
Cc: |
'EPICS Tech Talk' <[email protected]> |
Date: |
Wed, 24 Jan 2018 09:51:04 -0600 |
On 01/23, Mark Engbretson wrote:
> For whatever it is worth, there are a large number of Ethernet devices
> that have to be manually reset at the APS when the network police run
> their various port scans - PLC systems, Area Detectors, Galil Ethernet
> motor controllers, whatever.
Hi, Mark.
Frankly, that's sad.
> Their docs also state clearly that such hardware is intended to
> be used on an isolated or protected network. I do not think that
> any software or hardware vendor is going to say their server
> implementations can 100% survive what is essentially a DOS attack.
A port scan is not a DOS attack. Software that crashes due to receiving
an invalid packet has a DOS vulnerability because that vulnerability
could be used in a DOS attack. Obviously, I understand that the
software is intended to be used on a trusted network, but crashing
because it receives an invalid packet is a bug and should be fixed.
Lewis
- Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Shuei YAMADA
- Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
- Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] J. Lewis Muir
- Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Benjamin Franksen
- Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Hartman, Steven M.
- Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Michael Davidsaver
- RE: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Mark Engbretson
Career Opportunity White, Karen S.
<2018>
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Mark Rivers
<2018>
