1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: Simon Reiter <[email protected]>, <[email protected]>
Date: Tue, 30 Jan 2018 15:57:33 +0100
On 01/30/2018 03:13 PM, Simon Reiter wrote:
> while updating our IOC from EPICS 3.14.12.6 to 3.16.1 I discovered a
> problem with the event record.
> I use several binary output records, which listen to event number 2. If
> the corresponding event record is processed, the binary output records
> do no process. If I force them to with "dbpf <PV-NAME>.PROC 0", it works.
> The IOC is running on a PowerPC.
> I use
>   field(SCAN, "Event")
>   field(EVNT, "2")
> in the bo record.
> Have there been changes in the event record or shall I use a different
> way to trigger these output PVs?
I found this in the release notes for 3.15:
Named Soft Events
Soft events can now be given meaningful names instead of just using the
numbers 1-255. The EVNT field is now a DBF_STRING. The post_event() API
is now deprecated but still works. It should be replaced by code that in
advance looks up the EVNTPVT event handle associated with the named
event by calling eventNameToHandle(char *), and when that event occurs
passes that handle to the new postEvent(EVNTPVT) routine (which may be
called from interrupt level). A new iocsh command postEvent name will
trigger a named event from the command-line or a startup script (on
vxWorks the expression postEvent(eventNameToHandle("name")) must be used
instead though).
HTH
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Prev: pvPut error message by Sequencer Simon Reiter
Next: Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvPut error message by Sequencer Andrew Johnson
Next: Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
