Hi Simon,
On 01/30/2018 09:41 AM, Simon Reiter wrote:
> using caput results in the same error message.
> I added the OMSL field with "supervisory" to the binary output record,
> but still fails.
> Since I do not care, if it is output or input PV, I can switch. But it
> would be nice, to understand this problem.
It's a known internal bug in Base-3.16.1 which happened while making
link types extensible. Ralph pointed you to the Known Problems page; it
links to https://epics.anl.gov/base/R3-16/1-docs/msg503.patch which
should fix this issue if you apply the patch to your copy of Base and
rebuild.
HTH,
- Andrew
- Scanning on event number fails with EPICS 3.16 Simon Reiter
- pvPut error message by Sequencer Simon Reiter
- Re: pvPut error message by Sequencer Benjamin Franksen
- Re: pvPut error message by Sequencer Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Michael Davidsaver
Re: Scanning on event number fails with EPICS 3.16 Andrew Johnson
<2018>
Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
<2018>
