Even when I solved the issue different, I appreciate that you keep
working on this.
Simon
On 02/08/2018 02:23 PM, Dirk Zimoch wrote:
Attached is a patch file for dbScan.c which should fix the problem and
restore backward compatibility.
I have created (and quickly tested) it with EPICS 7 but I guess it
should work with 3.16 as well.
The hack is to treat "x.000000" and "x" as the same event name if x is
an integer between 0 and 255. ("0" and "0.000000" are no event at all
now just like "").
I will create a merge request for the EPICS base repo once I have
proper tests and documentation.
Dirk
On 08.02.2018 10:08, Dirk Zimoch wrote:
This is interesting. When I wrote the "named Events" feature some
years ago, I tested with something like 2 which became "2" and all
was fine. However I never thought about generating the value from a
calc. This should be fixed, or at least "2.000000" and "2" should be
treated as equal.
I will start working on it...
Dirk
On 30.01.2018 17:20, Simon Reiter wrote:
Thanks so far.
postEvent 2
works fine.
Up to now, my event record has an INP field, which links to a calc
record.
This calc record only provides the correct value under some conditions.
How can I do this without using a state machine?
record(calc,"$(BOARDNAME):ErrorFlags:calc")
field(INPA, "$(BOARDNAME):InitDone:S CPP")
field(CALC, "A ? 2 : 0")
record(event, "$(BOARDNAME):ErrorFlags:trg")
field(INP, "$(BOARDNAME):ErrorFlags:calc CPP")
This is my current code. The value of event is now 2.000000 in the
correct case.
Simon Reiter
II. Physikalisches Institut
Justus-Liebig-Universtität
Heinrich-Buff-Ring 16
D-35392 Giessen
Tel: +49 641 99 33250
- Scanning on event number fails with EPICS 3.16 Simon Reiter
- Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
- Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
- Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Re: Why is post_event deprecated? Till Straumann
Re: Why is post_event deprecated? Andrew Johnson
<2018>
Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
<2018>
ANJ, 08 Feb 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
