1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: 回复: Question about values of historic PVs dislpayed in CSS XY Graph widget
Date: Fri, 9 Feb 2018 13:58:19 +0000
In other words, I want to use XY graph widget to display the historic data getting from the database, can the widget achieve the goal. Do I need programming ?
Thanks in advance again.
发件人: lzf neu
发送时间: 2018-02-09 21:14
收件人: [email protected]
抄送: lzf neu
主题: Question about values of historic PVs dislpayed in CSS XY Graph widget
    I use the pre-configured for the SNS Office version of CSS (sns-css-4.1.1), and I intend to plot the values of live PVs and historic PVs in XY Graph widget.
    I have tried drag the pv name on the XY graph widget and only the values of live PVs could display, and when refreshing the widget all the values are cleared.
    I want to consult you that how the XY graph widget achieve the same functions as that of Data Browser widget. The funcitons include getting the values of historic data by random time intervals from mysql and display the raw data or optimised data and so on.
    Any help will be appreciated and thanks in advance.
Zhefu
Question about values of historic PVs dislpayed in CSS XY Graph widget lzf neu
Prev: Re: FLNK length limit Kasemir, Kay
Next: RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Question about values of historic PVs dislpayed in CSS XY Graph widget lzf neu
Next: Re: 回复: Question about values of historic PVs dislpayed in CSS XY Graph widget Shen, Guobao
ANJ, 09 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
