1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 回复: Question about values of historic PVs dislpayed in CSS XY Graph widget
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 Feb 2018 15:25:35 +0000
If you want to plot your live data together the data from archiver, you can use data browser.
You can drag the PV into data browser, and tell data browser how many history data you want to retrieve from archiver.
It plots all you wanted archived data, then continuously add your live data together with it.
Guobao
From: <[email protected]> on behalf of lzf neu <[email protected]>
Date: Friday, February 9, 2018 at 7:58 AM
Subject:
Thanks in advance again.
发件人: lzf neu
发送时间: 2018-02-09 21:14
收件人: [email protected]
抄送: lzf neu
主题: Question about values of historic PVs dislpayed in CSS XY Graph widget
    I use the pre-configured for the SNS Office version of CSS (sns-css-4.1.1), and I intend to plot the values of live PVs and historic PVs in XY Graph widget.
    I have tried drag the pv name on the XY graph widget and only the values of live PVs could display, and when refreshing the widget all the values are cleared.
    I want to consult you that how the XY graph widget achieve the same functions as that of Data Browser widget. The funcitons include getting the values of historic data by random time intervals from mysql and display the raw data or optimised data and so on.
    Any help will be appreciated and thanks in advance.
Zhefu
Prev: RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mark Rivers
Next: Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Johannes Spinneken (EGI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 回复: Question about values of historic PVs dislpayed in CSS XY Graph widget lzf neu
Next: Re: Where is histogram? Southern, Tim
ANJ, 09 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
