Oops. Here's the corrected one. On this URL [1] a version 3-12 is mentioned. I'm not sure if the github repo is kept up to date with the tarballs in [1].[1] https://www.gmca.aps.anl.gov/TPMAC2/ Bruno On Thu, Feb 15, 2018 at 3:55 PM, Mark Rivers <[email protected]> wrote:
diff --git a/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp b/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp index aba5b37..36cc123 100644 --- a/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp +++ b/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp @@ -322,19 +322,23 @@ asynStatus pmacController::lowLevelWriteRead(const char *command, char *response //Use the controller-wide param PMAC_C_CommsError_ getIntegerParam(PMAC_C_CommsError_, &commsError); - if (!commsError) { - status = pasynOctetSyncIO->writeRead(lowLevelPortUser_ , + status = pasynOctetSyncIO->writeRead(lowLevelPortUser_ , command, strlen(command), response, PMAC_MAXBUF_, PMAC_TIMEOUT_, &nwrite, &nread, &eomReason ); - if (status) { - asynPrint(lowLevelPortUser_, ASYN_TRACE_ERROR, "%s: Error from pasynOctetSyncIO->writeRead. command: %s\n", functionName, command); - setIntegerParam(PMAC_C_CommsError_, PMAC_ERROR_); - } else { - setIntegerParam(PMAC_C_CommsError_, PMAC_OK_); - } + if (status) { + asynInterface *pasynInterface = pasynManager->findInterface(lowLevelPortUser_, + asynCommonType, true); + asynCommon *pasynCommon = (asynCommon*) pasynInterface->pinterface; + + asynPrint(lowLevelPortUser_, ASYN_TRACE_ERROR, "%s: Error from pasynOctetSyncIO->writeRead. command: %s, status=%d\n", functionName, command, status); + setIntegerParam(PMAC_C_CommsError_, PMAC_ERROR_); + pasynCommon->disconnect(pasynInterface->drvPvt, lowLevelPortUser_); + + } else { + setIntegerParam(PMAC_C_CommsError_, PMAC_OK_); } asynPrint(lowLevelPortUser_, ASYN_TRACEIO_DRIVER, "%s: response: %s\n", functionName, response);
ANJ, 15 Feb 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
