1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Dexela .dll missing when compiling WITH_PVA=YES
Date: Sun, 18 Feb 2018 13:28:41 +0000
I am reposting this because my original post was too large.
Sent: Saturday, February 17, 2018 1:43 PM
To: 'Gofron, Kazimierz'; '[email protected]'
Subject: RE: Dexela .dll missing when compiling WITH_PVA=YES
Hi Kaz,
I found the required DLLs and put them in the directory with the bin\windows-x64-static-vs2017 directory with DexelaApp.exe.
The IOC starts fine, as shown in the following.  It gives an error (in red) because it cannot find the detector (I don’t have one), but you can see that it executes the NDPvaConfigure and startPvsServer commands (in red), so it was definitely built with PVA.  I cannot reproduce your problem of the IOC failing to start.
J:\epics\devel\areaDetector-3-2\ADDexela\iocs\dexelaIOC\iocBoot\iocDexela>..\..\bin\windows-x64-static-vs2017\DexelaApp.exe st.cmd
errlogInit(20000)
< envPaths
epicsEnvSet("IOC","iocDexela")
epicsEnvSet("TOP","J:/epics/devel/areaDetector-3-2/ADDexela/iocs/dexelaIOC")
epicsEnvSet("ADDEXELA","J:/epics/devel/areaDetector-3-2/ADDexela/iocs/dexelaIOC/../..")
epicsEnvSet("SUPPORT","J:/epics/devel")
epicsEnvSet("ASYN","J:/epics/devel/asyn-4-33")
epicsEnvSet("AREA_DETECTOR","J:/epics/devel/areaDetector-3-2")
epicsEnvSet("ADSUPPORT","J:/epics/devel/areaDetector-3-2/ADSupport")
epicsEnvSet("ADCORE","J:/epics/devel/areaDetector-3-2/ADCore")
epicsEnvSet("AUTOSAVE","J:/epics/devel/autosave-5-9")
epicsEnvSet("BUSY","J:/epics/devel/busy-1-7")
epicsEnvSet("CALC","J:/epics/devel/calc-3-7")
epicsEnvSet("SNCSEQ","J:/epics/devel/seq-2-2-5")
epicsEnvSet("SSCAN","J:/epics/devel/sscan-2-11-1")
epicsEnvSet("DEVIOCSTATS","J:/epics/devel/devIocStats-3-1-15")
epicsEnvSet("EPICS_BASE","H:/epics-devel/base-7.0.1")
dbLoadDatabase("J:/epics/devel/areaDetector-3-2/ADDexela/iocs/dexelaIOC/dbd/DexelaApp.dbd")
DexelaApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "13DEX1:")
# The port name for the detector
epicsEnvSet("PORT",   "DEX1")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2048")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "2048")
# The maximum number of time seried points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "J:/epics/devel/areaDetector-3-2/ADCore/db")
# Create a Dexels driver
# DexelaConfig(const char *portName, detIndex, maxBuffers, size_t maxMemory, int priority, int stackSize)
# This is for the first detector in the system
DexelaConfig("DEX1", 0, 0, 0, 0, 0)
Error Occurred at unknown file, line 5654, column 3.
2018/02/17 13:36:45.151 Dexela::Dexela Error: no Dexela devices found
asynSetTraceIOMask(DEX1, 0, 2)
#asynSetTraceMask($(PORT),0,0xff)
dbLoadRecords("J:/epics/devel/areaDetector-3-2/ADDexela/iocs/dexelaIOC/../../db/Dexela.template", "P=13DEX1:,R=cam1:,PORT=DEX1,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from Driver.
NDStdArraysConfigure("Image1", 3, 0, "DEX1", 0)
# Set NELEMENTS to at least the total number of pixels in the detector.  The following is a little larger than 4096 x 4096
dbLoadRecords("J:/epics/devel/areaDetector-3-2/ADCore/db/NDStdArrays.template", "P=13DEX1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1,TYPE=Int16,SIZE=16,FTVL=SHORT,NE
LEMENTS=17000000")
# Load all other plugins using commonPlugins.cmd
< J:/epics/devel/areaDetector-3-2/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileNetCDF.template","P=13DEX1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=13DEX1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileJPEG.template",  "P=13DEX1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileNexus.template", "P=13DEX1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileHDF5.template",  "P=13DEX1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a Magick file saving plugin
NDFileMagickConfigure("FileMagick1", 20, 0, "DEX1", 0)
dbLoadRecords("NDFileMagick.template","P=13DEX1:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=13DEX1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
NDROIConfigure("ROI2", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=13DEX1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
NDROIConfigure("ROI3", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=13DEX1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
NDROIConfigure("ROI4", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=13DEX1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 20, 0, "DEX1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=13DEX1:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=13DEX1:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "DEX1", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=13DEX1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 20, 0, "DEX1", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=13DEX1:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=13DEX1:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDGatherN.template",   "P=13DEX1:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=13DEX1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=DEX1")
NDStatsConfigure("STATS2", 20, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=13DEX1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=DEX1")
NDStatsConfigure("STATS3", 20, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=13DEX1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=DEX1")
NDStatsConfigure("STATS4", 20, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=13DEX1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=DEX1")
NDStatsConfigure("STATS5", 20, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=13DEX1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=DEX1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=13DEX1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "DEX1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=13DEX1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=13DEX1:ROI1:MinX_RBV,YPOS=13DEX1:ROI1:MinY_RBV,XSIZE=13DEX1:ROI1:SizeX_RBV,YSIZE=13DEX1
:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=13DEX1:ROI2:MinX_RBV,YPOS=13DEX1:ROI2:MinY_RBV,XSIZE=13DEX1:ROI2:SizeX_RBV,YSIZE=13DEX1
:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=13DEX1:ROI3:MinX_RBV,YPOS=13DEX1:ROI3:MinY_RBV,XSIZE=13DEX1:ROI3:SizeX_RBV,YSIZE=13DEX1
:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=13DEX1:ROI4:MinX_RBV,YPOS=13DEX1:ROI4:MinY_RBV,XSIZE=13DEX1:ROI4:SizeX_RBV,YSIZE=13DEX1
:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=
junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=
junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=
junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=13DEX1:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=
junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=13DEX1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
NDColorConvertConfigure("CC2", 20, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=13DEX1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 20, 0, "DEX1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=13DEX1:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 20, 0, "DEX1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=13DEX1:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=DEX1")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=13DEX1:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create an FFT plugin
NDFFTConfigure("FFT1", 3, 0, "DEX1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=13DEX1:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=DEX1, NAME=FFT1, NCHANS=2048")
set_requestfile_path("./")
set_requestfile_path("J:/epics/devel/areaDetector-3-2/ADCore/ADApp/Db")
set_requestfile_path("J:/epics/devel/areaDetector-3-2/ADCore/iocBoot")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("13DEX1:")
dbLoadRecords("J:/epics/devel/autosave-5-9/asApp/Db/save_restoreStatus.db", "P=13DEX1:")
# Optional: load NDPluginPva plugin
NDPvaConfigure("PVA1", 20, 0, "DEX1", 0, 13DEX1:Pva1:Image, 0, 0, 0)
dbLoadRecords("NDPva.template",  "P=13DEX1:,R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DEX1")
# Must start PVA server if this is enabled
startPVAServer
2018-02-17T13:36:47.515 No broadcast addresses found or specified - empty address list!
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
# Optional: load scan records
dbLoadRecords("J:/epics/devel/sscan-2-11-1/sscanApp/Db/scan.db", "P=13DEX1:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
set_requestfile_path("J:/epics/devel/sscan-2-11-1/sscanApp/Db")
# Optional: load sseq record for acquisition sequence
dbLoadRecords("J:/epics/devel/calc-3-7/calcApp/Db/sseqRecord.db", "P=13DEX1:, S=AcquireSequence")
set_requestfile_path("J:/epics/devel/calc-3-7/calcApp/Db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
dbLoadRecords("J:/epics/devel/devIocStats-3-1-15/db/iocAdminSoft.db", "IOC=13DEX1:")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
set_requestfile_path("J:/epics/devel/areaDetector-3-2/ADDexela/iocs/dexelaIOC/../../dexelaApp/Db")
iocInit()
Starting iocInit
## EPICS R7.0.1.2-DEV
## EPICS Base built Feb 16 2018
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of Gofron, Kazimierz
Sent: Friday, February 16, 2018 10:06 PM
To: [email protected]<mailto:[email protected]>
Subject: Dexela .dll missing when compiling WITH_PVA=YES
When Dexela detector is compiled ‘WITH_PVA=YES’, the Dexela.exe application crashes on start, without ever reaching any part of st.cmd file.
With ‘WITH_PVA=NO’, the ioc starts correctly. Compared to the prebuild, and one build ‘WITH_PVA=YES’ the following libraries are not linked:
GDI32.dll
OLEAUT.dll
PSAPI.dll {only in prebuild with base-3.15.5}
I am not sure why these windows 7 libraries are excluded when PVA (V4) is used?
base-7.0.1.1
Visual Studio Community Edition 2017
make-4.2.1
Windows 7 Pro 64 bit
windows-x64-static
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
Dexela .dll missing when compiling WITH_PVA=YES Gofron, Kazimierz
RE: Dexela .dll missing when compiling WITH_PVA=YES Mark Rivers
Prev: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Next: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Dexela .dll missing when compiling WITH_PVA=YES Mark Rivers
Next: RE: Dexela .dll missing when compiling WITH_PVA=YES Gofron, Kazimierz
ANJ, 18 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
