On 05/03/2018 11:19 AM, Konrad, Martin wrote:
> Hi Anton, Ralph,
>> I get a bit jealous every time I see "bottom-to-top" setups with
>> CIs, push triggering, automatic testing and such - that is until I
>> imagine something goes wrong and, say, a malformed input just drags a
>> trace through the entire setup.
> Sure it does. But the same is true if you build and deploy manually. We
> are trying to prevent issues by:
> - Maintaining a "master" branch which gets build into an "unstable"
> Debian repo and a "release" branch which gets build into a "release"
> Debian repo. Releasing means merging to the release branch.
> - We have set up a test network that mimics our production network. We
> deploy from the "unstable" repo into this test environment and from the
> "release" one into the production network. Nothing goes out to
> production without test and approval.
Is it still the case that moving between unstable and release involves
a rebuild in a different environment resulting in a different set
of binaries?
> - We are trying to have one piece of each device on the test network. In
> other cases we are simulating hardware. The fact that FRIB is heavily
> using VMs and only a small number of physical IOCs helps to keep the
> cost for such a test environment low.
>> Even if that doesn't break production right away, cleaning things up
>> may be troublesome.
> If we broke something we can roll back. This can be done either by
> a) reverting the bad commit in Git and waiting for the new packages to
> be build and distributed or
> b) installing an older version of the affected package(s)
> Both approaches work well for us.
>> What different in the "FRIB version numbers" is that upload comes
>> before distribution - doesn't it mean that a recent upload for, say,
>> jessie will sort as newer when compared to an older upload for
>> stretch? And the system will consider it to be newer if it sees
>> both.
> We attach the timestamp when our CI server builds the _source_ package.
> If the same source package gets build for multiple distributions the
> version number of the resulting packages is the same except for the
> distribution name. The package build for stretch ("debian09") will sort
> as newer as the one for jessie ("debian08"). This ensures we upgrade to
> the stretch package after dist-upgrading a machine.
> Regarding the Git hash in the version number: I like this feature as it
> allows me to directly correlate packages (including "unstable" builds)
> to a revision in Git. I agree that this is less important for production
> builds if they get tagged anyway. But to be honest I trust the Git hash
> more than a tag that could get modified later. We still maintain normal
> version numbers (e.g. "4.33") for readability but we never saw a reason
> to remove the additional stuff (timestamp, build number and Git hash) -
> it can easily be ignored if not needed.
> -Martin
signature.asc
Description: OpenPGP digital signature
- Re: NSLS-II Debian Repository in 2018 Anton Derbenev
- Re: NSLS-II Debian Repository in 2018 Ralph Lange
- Re: NSLS-II Debian Repository in 2018 Konrad, Martin
RE: EPICS Support for RedPitaya Release v2.0 Andraz Pozar
<2018>
<2018>
