1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: How do you generate nexus files?
Date: Wed, 9 May 2018 08:56:00 -0300
Here at Brazilian Synchrotron (LNLS) we are working to implement nexus on some beamlines. We are working with python, getting all data from epics PVs and build nexus files. On all the cases the most important data are waveforms.
We would like to analyses other possibilities, and to verify how other synchrotrons generate nexus files:
Do you are working with nexus files?
How do you generate them?
Are you using some high level language for it (like python, c++) ?
Is it possible to generate nexus files using areadetector for instance (with more than one "source", including waveform) ?
Thank you.
Regards
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Re: How do you generate nexus files? Matt Newville
Re: How do you generate nexus files? Mark Rivers
Prev: RE: Keithley 2634B Source Meter Kline, David
Next: Re: How do you generate nexus files? Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: RE: Keithley 2634B Source Meter [email protected]
ANJ, 10 May 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
