Hi Gabriel,
On Wed, May 9, 2018 at 6:56 AM, Gabriel de Souza Fedel <[email protected]> wrote: Hi, Yes, many beamline groups at the APS use nexus, especially in the sense that nexus is HDF5+naming conventions. How do you generate them? From python, nexpy (https://github.com/nexpy/nexpy) is very useful for working with nexus data, either from plain python programs, or from its very nice GUI. You can also sort of "roll your own" by using HDF5 + the nexus conventions. That's probably not "recommended", but it can work in a pinch. Is it possible to generate nexus files using areadetector for instance (with more than one "source", including waveform) ? Yes, there is a nexus plugin for areadetector. In addition, the HDF5 plugin follows (as far as I know) the nexus conventions, and can also be discovered and handled well by nexus tools. --Matt Newville
ANJ, 09 May 2018 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
