Is there a way to modify the appearance of the dropdown in a combo widget in CSS BOY? The dropdown is not as wide as the combo itself (it appears to derive its width from the widest element in the dropdown list). Also, the background of
the dropdown matches the background of the OPI so it doesn’t stand out very well. Finally, for a write-combo, if I set the background to ‘Write_Background’ (a cyan color), then much of the combo frame is still gray but the cyan color shows up in the selected
text as well as around the frame. Is there any way to modify this?
Thank you,
--Ray
Re: How do you generate nexus files? Matt Newville
Re: How do you generate nexus files? Mark Rivers
<2018>
Re: How do you generate nexus files? Gabriel de Souza Fedel
devAsynUInt32Digital: add parameter for shifting? Konrad, Martin
<2018>
ANJ, 09 May 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
