Hi Gabriel,
> Is it possible to generate nexus files using areadetector for instance (with more than one "source", including waveform) ?
Nexus files can be generated in areaDetector either with the NDFileHDF5 plugin (recommended) or the Nexus plugin (soon to be deprecated).
The HDF5 plugin stores the data for one or more NDArrays, including all of the NDAttributes attached to those arrays. NDAttributes are limited to scalar values of any data type (signed/unsigned 8/16/32-bit integers, 32/64 bit float, and strings). NDAttributes cannot be arrays (waveforms).
So it is not currently possible to do what you are asking with the NDFileHDF5 plugin, i.e. store arrays of different sizes from different sources in the same HDF5 file.
In the future it would be possible to extend NDAttributes to handle arrays, and it is has certainly been considered in the past. The question is the scope: do we support just 1-D waveforms, or N-dimensional arrays? If N-dimensional then should such arrays be NDArrays, and can they themselves have attributes? That would become a complex project.
From: [email protected] <[email protected]> on behalf of Gabriel de Souza Fedel <[email protected]>
Sent: Wednesday, May 9, 2018 6:56 AM
To: [email protected]
Subject: How do you generate nexus files?
Here at Brazilian Synchrotron (LNLS) we are working to implement nexus
on some beamlines. We are working with python, getting all data from
epics PVs and build nexus files. On all the cases the most important
data are waveforms.
We would like to analyses other possibilities, and to verify how other
synchrotrons generate nexus files:
Do you are working with nexus files?
How do you generate them?
Are you using some high level language for it (like python, c++) ?
Thank you.
Regards
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron - (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br<http://www.lnls.cnpem.br>
- Re: How do you generate nexus files? Pete Jemian
- Re: How do you generate nexus files? Gabriel de Souza Fedel
- How do you generate nexus files? Gabriel de Souza Fedel
combo dropdowns in CSS BOY Gregory, Ray
RE: Keithley 2634B Source Meter [email protected]
<2018>
<2018>
