Hi Douglas,
This looks like an issue with your local pc network arrangements. How is your gateway and netmask set at your local pc? Would you mind sending the output of ifconfig on local pc and detector? Does the IOC work at the beamline if you run it at the same computer as you used the DppMCA software?
Cheers, Hugo
On Wed, May 16, 2018 at 12:52 PM Douglas Henrique C. de Araújo < [email protected]> wrote:
Hi Hugo,
Now I'm doing test in my local pc with IP 10.2.101.36 and the
detector is connected in 10.2.103.31. in this case the ioc can't
find the detector. We already configured the broadcast, but not
has changed.
When I connect the detector in other port (10.2.101.34) the ioc
works.
Another important point is that when we connected the detector in
beamline network (subnet: 10.2.78.0) and we used the DppMCA
Windows program (Running a windows pc on the subnet: 10.2.76.0),
the DppMCA recognizes the detector.
Thank You
Regards
Em 16-05-2018 15:49, Hugo Slepicka
escreveu:
Hi Douglas,
Can you provide more information about the IOC server
network and also the detector network? (IP, Network Mask,
Gateway, etc)...
Thank you,
Hugo
On Wed, May 16, 2018 at 10:51 AM Douglas Henrique
Hi, I'm
using the amptek ioc from support mca7-7, and if the detector
is
on the same network (and subnet) as the IOC server, it
recognizes and
works perfectly. But if I change the detector subnet, the ioc
can't find
the detector.
Does anyone knows if there is some configuration so that the
amptek IOC
recognizes the detector that is connected in another subnet?
Or has
anyone had a similar problem?
Thank you
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br
www.lnls.br
- Re: Amptek IOC: Problem with subnet Mark Rivers
- Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
- Re: Amptek IOC: Problem with subnet Hugo Slepicka
- Re: Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Reminder: June EPICS Meeting at Argonne Andrew Johnson
<2018>
<2018>
ANJ, 16 May 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
