1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Amptek IOC: Problem with subnet
From: Douglas Henrique C. de Araújo <[email protected]>
To: Mark Rivers <[email protected]>, Hugo Slepicka <[email protected]>
Date: Thu, 17 May 2018 13:18:32 -0300
Em 16-05-2018 22:41, Mark Rivers escreveu:
Now I'm doing test in my local pc with IP 10.2.101.36 and the detector is connected in 10.2.103.31.
in this case the ioc can't find the detector.
We already configured the broadcast, but not has changed.
When I connect the detector in other port (10.2.101.34) the ioc works.
You need to explain more.  When you change the detector from 10.2.101.34 to 10.2.103.31 are you also physically moving the detector to a different subnet?  Or are you simply changing the IP address.  If the the former, then is there a firewall between the 2 subnets?  If you are simply changing the IP address but not physically moving to another subnet then that is not going to work.
Hi Mark
 I'm physically moving the detector to a different subnet, and there isn't configured firewall between the 2 subnets. My machine can ping the detector ip (10.2.103.31) normally.
Thanks you
Douglas
When the detector address is 10.2.103.31 can you ping it is from your machine at 10.2.101.36?
From: [email protected] <[email protected]> on behalf of Hugo Slepicka <[email protected]>
Sent: Wednesday, May 16, 2018 3:02 PM
To: Douglas Henrique C. de Araújo
Cc: [email protected]
Hi Douglas,
This looks like an issue with your local pc network arrangements. How is your gateway and netmask set at your local pc?
Would you mind sending the output of ifconfig on local pc and detector?
Does the IOC work at the beamline if you run it at the same computer as you used the DppMCA software?
Cheers,
Hugo
On Wed, May 16, 2018 at 12:52 PM Douglas Henrique C. de Araújo <[email protected]<mailto:[email protected]>> wrote:
Hi Hugo,
Now I'm doing test in my local pc with IP 10.2.101.36 and the detector is connected in 10.2.103.31. in this case the ioc can't find the detector. We already configured the broadcast, but not has changed.
    Hi Hugo,
        Local PC:
        eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.2.101.36  netmask 255.255.255.0  broadcast 10.2.101.255
        Gateway: 10.2.101.1
        About the detector, i have only the ip (10.2.103.31),  the detector doesn't has a system where a can login and doing a ifconfig. but the net here is configured to has the same netmask and gateway, and the detector get ip by dhcp.
        Thank you
        Douglas
Another important point is that when we connected the detector in beamline network (subnet: 10.2.78.0) and we used the DppMCA Windows program (Running a windows pc on the subnet: 10.2.76.0), the DppMCA recognizes the detector.
Thank You
Regards
Em 16-05-2018 15:49, Hugo Slepicka escreveu:
Hi Douglas,
Can you provide more information about the IOC server network and also the detector network? (IP, Network Mask, Gateway, etc)...
Thank you,
Hugo
On Wed, May 16, 2018 at 10:51 AM Douglas Henrique C. de Araújo <[email protected]<mailto:[email protected]>> wrote:
Hi, I'm using the amptek ioc from support mca7-7, and if the detector is
on the same network (and subnet) as the IOC server, it recognizes and
works perfectly. But if I change the detector subnet, the ioc can't find
the detector.
Does anyone knows if there is some configuration so that the amptek IOC
recognizes the detector that is connected in another subnet? Or has
anyone had a similar problem?
Thank you
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron - (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected]<mailto:[email protected]> | +55 (19) 3512 1228<tel:+55%2019%203512-1228>
www.lnls.br<http://www.lnls.br>
Laboratório Nacional de Luz Síncrotron – (LNLS)
[email protected] | +55 (19) 3512 1228
www.lnls.br
Re: Amptek IOC: Problem with subnet Mark Rivers
Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Re: Amptek IOC: Problem with subnet Hugo Slepicka
Re: Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Prev: Re: Question regarding asynParamInt32Array Mark Rivers
Next: Re: Amptek IOC: Problem with subnet Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Amptek IOC: Problem with subnet Mark Rivers
ANJ, 17 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
