1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Parsing problem with stream
To: <[email protected]>
Date: Mon, 4 Jun 2018 16:49:30 +0200
Hi Richard,
You can limit the scope of a checksum like this: %1<xor8ff>
A checksum like %A.B<...> ignores A bytes at the beginning and B bytes at the end.
For fixed-length input you can use maxInput=number_of_byes; instead of a terminator.
Dirk
On 04.06.2018 16:30, Lucock, Richard M wrote:
     I am having problems parsing data from a serial device (ie
obtained using asyn & stream). The normal protocol is to send a
message (with checksum), wait for an ACK character, then read the
reply (which has a checksum).
If I read the ACK and the reply on one line, using the protocol below:
    read_version {
       out STX, "001?f" ETX, "%<xor8ff>";
       in ACK, STX, "001 f%[^\003]", ETX, "%<xor8ff>";
then I get the correct data into my 'stringin' record, but the shell
reports that the checksum is wrong (presumably because the ACK has
been included in the calculation). If I separate out the ACK and the
reply inputs:
    read_version {
       in ACK;
       in STX, "001 f%[^\003]", ETX, "%<xor8ff>";
then the shell reports no errors, but nothing is placed in my
'stringin' record.
The messages have no terminators, which I guess is part of the
problem. I have tried playing about with 'extrainput', 'maxinput' and
'wait', with no luck. Does anyone have any suggestions for dealing
with this ?
     Richard
Re: Parsing problem with stream Lucock, Richard M
Prev: Parsing problem with stream Lucock, Richard M
Next: Re: Parsing problem with stream Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Parsing problem with stream Lucock, Richard M
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
