Hey Richard,
I actually do not know, why your second solution is not working.
I have a device with a similar protocol where I use this approach
and it works.
Anyhow. You could use your first solution, but exclude the ACK
from the checksum with the width/precision flags. From the
documentation:
> The width field is the byte number from which to
start
calculating the checksum.
Default is 0, i.e. the first byte of the input or output of the
current
command.
The last byte is precision bytes before the checksum
(default 0).
For example in "abcdefg%<xor>" the checksum is
calculated
from abcdefg ,
but in "abcdefg%2.1<xor>" only from cdef .
So in your case you could use:
in ACK, STX, "001 f%[^\003]", ETX, "%1<xor8ff>";
Hope this helps!
Florian
On 06/04/2018 04:30 PM, Lucock, Richard
M wrote:
I am having problems parsing data from a serial device (ie
obtained using asyn & stream). The normal protocol is to send
a
message (with checksum), wait for an ACK character, then read the
reply (which has a checksum).
If I read the ACK and the reply on one line, using the protocol
below:
read_version {
out STX, "001?f" ETX, "%<xor8ff>";
in ACK, STX, "001 f%[^\003]", ETX, "%<xor8ff>";
then I get the correct data into my 'stringin' record, but the
shell
reports that the checksum is wrong (presumably because the ACK has
been included in the calculation). If I separate out the ACK and
the
reply inputs:
read_version {
in ACK;
in STX, "001 f%[^\003]", ETX, "%<xor8ff>";
then the shell reports no errors, but nothing is placed in my
'stringin' record.
The messages have no terminators, which I guess is part of the
problem. I have tried playing about with 'extrainput', 'maxinput'
and
'wait', with no luck. Does anyone have any suggestions for dealing
with this ?
Richard
| Dr. Florian Feldbauer |
| Ruhr-Universität Bochum |
| Experimentalphysik I AG |
| Universitätsstr 150 |
| D-44801 Bochum |
| Office: NB 2/134 |
| Phone: (+49)234 / 32-23563 |
- Parsing problem with stream Lucock, Richard M
Re: Parsing problem with stream Dirk Zimoch
Re: Linkam T96 System Controller Kevin Peterson
<2018>
Re: Parsing problem with stream Lucock, Richard M
MVME3100 FPU Support on RTEMS 4.10.2 Matt Rippa
<2018>
ANJ, 06 Jun 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
