Subject: |
Re: Stringin - asynOctedRead type how to set string length |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Tue, 5 Jun 2018 13:32:06 +0200 |
Hi Pilar,
The long string input (lsi) and long string output (lso) records in EPICS Base are designed to handle strings longer than the capacity of the classical Channel Access string type. For these record types, the SIZV field configures the length of the internal buffers, while the LEN field contains the actual length of the string in the VAL field.
Cheers, ~Ralph
Hello Mark,
I would like to send a string which length is bigger than 40.
But as Ronaldo has mentioned, maybe it is better to try it
using a waveform.
Thank you very much for your answers!
Pilar
- Re: Stringin - asynOctedRead type how to set string length Mark Rivers
- Modify checkbox value from a table widget Pilar Gil Jaldo
- Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
- Re: Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
<2018>
<2018>
ANJ, 05 Jun 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
