Thanks for the ideas. It's intriguing this 1 second delay is not long enough. Our change from VxWorks to RTEMS did not change the fundamental application logic. The changes were OSI semantics. Further, the CPU loads are only ~10-20% viewing iocStats. Is that the best assessment of a system being "busy" ? Perhaps iocStats doesn't give enough resolution. We're collecting data from new tests at both our sites and should know more tomorrow. I ran a quick ping test and interestingly the VxWorks IOC shows higher rtt mdev: RTEMS: 53 packets transmitted, 53 received, 0% packet loss, time 52045ms
rtt min/avg/max/mdev = 1.126/1.153/1.204/0.038 ms VxWorks: 53 packets transmitted, 53 received, 0% packet loss, time 52059ms
rtt min/avg/max/mdev = 0.951/1.052/1.902/0.184 ms -Matt On Thu, Jul 12, 2018 at 10:47 AM Michael Davidsaver <[email protected]> wrote: On 07/12/2018 01:12 PM, Andrew Johnson wrote:
ANJ, 16 Jul 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
