1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget randomly returns Channel connect timed out
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 16 Jul 2018 13:59:24 -0500
Hi Mark,
On 07/16/2018 12:18 PM, Mark Rivers wrote:
> I thought we were doing directed UDP broadcasts to Cisco switches at
> the APS.
> Isn't that doing a directed UDP broadcast to the switch for the
> 164.54.162.* subnet?
If my internal investigations are correct you have an HP ProCurve switch
connecting your two subnets, which is why this still works for you.
Apparently it *is* possible to configure Cisco switches to allow this,
according to the last answer to this StackOverflow question:
https://stackoverflow.com/questions/379015/udp-broadcast-packets-across-subnets
This article from Cisco seems to explain how:
  http://www.ciscopress.com/articles/article.asp?p=330807&seqNum=9
If you have a system available with a network interface on both subnets
you could also run a pair of UDP Broadcast Packet Relays to pass
broadcasts between them, on both ports 5064 and 5065. More information
on this is available at
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access#UDP_Broadcast_Packet_Relay
- Andrew
Re: caget randomly returns Channel connect timed out Matt Rippa via Tech-talk
Re: caget randomly returns Channel connect timed out Dirk Zimoch
Re: caget randomly returns Channel connect timed out Andrew Johnson
Re: caget randomly returns Channel connect timed out Michael Davidsaver
Re: caget randomly returns Channel connect timed out Dirk Zimoch via Tech-talk
RE: caget randomly returns Channel connect timed out Mark Rivers
Prev: RE: caget randomly returns Channel connect timed out Mark Rivers
Next: Re: caget randomly returns Channel connect timed out Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
