1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Stream Device: Parse response that includes checksum of command string
To: David Vine <[email protected]>
Cc: [email protected]
Date: Thu, 2 Aug 2018 18:19:54 -0700
I have no idea how to handle this in StreamDevice, but perhaps you could push an interposed interface on top of the standard ASYN serial or IPPort driver to handle the sequence numbers and checksumming?
On Aug 2, 2018, at 5:44 PM, David Vine <[email protected]> wrote:
Hi all,
i'm writing device support for the MeCom protocol for a TEC driver from Meerstetter Engineering.
In order to parse the response correctly I need to calculate a checksum thats not included in the response. This is because the response includes the checksum of the command and not the response.
For example:
Command format:
# address sequence_number command CRC16 terminator
# 01 15AA ?IF 257D \r
Response is:
# address sequence_number CRC16 terminator
# 01 15AA 257D \r
So to parse the response I need to calculate a CRC that's not included in the response. For example:
OUT "#0115AA?IF%<xmodem>\r"
IN "#0115AA%<xmodem>\r" but the CRC is for the OUT not the IN.
Any ideas would be much appreciated.
David
Eric Norum
RE: Stream Device: Parse response that includes checksum of command string [email protected]
Stream Device: Parse response that includes checksum of command string David Vine
Prev: Stream Device: Parse response that includes checksum of command string David Vine
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: RE: Stream Device: Parse response that includes checksum of command string [email protected]
ANJ, 03 Aug 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
