1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbGetPdbAddrFromLink dropped from 3.15 again
To: Till Straumann <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Thu, 2 Aug 2018 21:02:26 -0700
On 07/31/2018 01:16 PM, Till Straumann wrote:
> I'm running into the same issue that was discussed here:
> https://epics.anl.gov/tech-talk/2017/msg01247.php
> Michael's answer (https://epics.anl.gov/tech-talk/2017/msg01268.php)
> recommends replacing subRecord by aSubRecord -- however, my use case
> rather fits the first scenario mentioned by Michael: avoiding the overhead of dbGet()
> What is the recommended migration path for this case?
Can you give some more details?  How do you use the dbAddr* which was being returned?
> I guess I could use
>    dbGetNelements(const struct link*)
>    dbGetLinkDBFtype(const struct link*)
> to make sure the target of my link matches the expectations -- but there is
> no way to access the data the link points to without either making a copy
> (dbGet) or exploiting internals (which is deprecated/discouraged)
> Like other posters I'm looking for a minimally intrusive (and yet 'safe') solution
> for a legacy system with not much horse-power.
> - Till
Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Prev: Re: Stream Device: Parse response that includes checksum of command string Eric Norum
Next: Re: Stream Device: Parse response that includes checksum of command string Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
ANJ, 04 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
