1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DBE_PROPERTY and Gateway
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Aug 2018 22:48:47 +0000
It's been a while but from what I remember when you issue a DBE_PROPERTY monitor, the gateway will create a DBR_CTRL subscription so that it can catch the maximum number of fields. However, DBR_CTRL structures do not have the timestamp; so to pick up the timestamp, you may have to create two subscriptions and combine the information.
Hope that helps.
Murali
Prev: Re: Delta Tau motor control problem Kevin Peterson
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: DBE_PROPERTY and Gateway Dominic Oram - UKRI STFC
Next: Data browser web tool Vishnu Patel
ANJ, 07 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
