Hello,
I'm trying to pick up when a record's EGU changes within my OPI. I've configured the relevant setting in CS-Studio to monitor DBE_PROPERTY and this works fine locally.
However, when trying to do the same through a gateway CS-Studio will get the event but will not correctly update its units.
I wonder if this may be because the gateway is putting an undefined timestamp on the property event? E.g. I am getting:
C:\Instrument\Apps\EPICS>camonitor -m p LOCAL:PV
LOCAL:PV 2018-08-03 10:57:54.819651 10
C:\Instrument\Apps\EPICS>camonitor -m p PV:THROUGH:GATEWAY
PV:THROUGH:GATEWAY 2018-08-03 11:03:18.015750 10
PV:THROUGH:GATEWAY <undefined> 10
I am running version 2.1.0 of the gateway, base 3.15.5 and running under Windows.
My gateway has the -mask set to vap, from a quick look through the gateway code I'm not sure if this is required or not?
I'm happy to dig a bit further into this and put the work in to fix it but before I do does anyone else have experience of running a similar set up? Or any general insight into the issue?
Dominic Oram
ISIS Neutron and Muon Source
Re: streamDevice 32-Bit ULONG endianess Dirk Zimoch
Fwd: Re: Delta Tau motor control problem Mark Davis
<2018>
Re: Stream Device: Parse response that includes checksum of command string Dirk Zimoch
Re: DBE_PROPERTY and Gateway Shankar, Murali
<2018>
