Hi Lewis,
Sorry if my response was a bit confusing. I did realize what you were
asking, and I agree that having a stop button on the UI makes sense and
would generally be a faster and safer alternative to correcting a typo
in a setpoint.
But it is true that (prior to my setting the InPosBand value on the
controller to a non-0 value) that using the STOP field of the motor
record to stop a movement would also result in the motor record waiting
for the status value from the controller to indicate the last
movement-related command had completed, which would never happen
unless/until I directly (via a command-line shell on the controller
itself) gave the controller a new move command and let it complete the
move (I expect doing it through the vendor's IDE would achieve the same
thing).
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 8/3/2018 11:15 AM, J. Lewis Muir wrote:
On 08/02, Mark Davis wrote:
On 8/1/2018 3:45 PM, J. Lewis Muir wrote:
On 08/01, Mark Davis wrote:
I assume that the driver SHOULD still work with the default Yes
value. Using the No value is not only less efficient, but could be
a real problem. If someone makes a typo when entering a new
setpoint, it wouldn't matter if they realized their mistake and
quickly entered the correct setpoint before the device has moved
very much - It would still go all the way to the incorrect setting
before starting to move to the correct position.
Couldn't you just stop the move?
Interesting question.
I just tried giving it a new setpoint and then setting STOP to 1
before it finished moving. But the same problem occurs: It stops,
the done moving bit is till clear, and it won't take any new
setpoints.
My main point here was just about the user scenario you described where
the user makes a mistake and then tries to quickly enter the correct
setpoint, but the motor goes all the way to the incorrect setpoint
before starting the move to the correct setpoint. I was just suggesting
that the user could quickly stop the move rather than quickly entering
a new setpoint. That works, right? The motor doesn't continue moving
to the incorrect setpoint after the user has commanded a stop, right? I
understand your bigger issue with the behavior, but just from a safety
point of view for the user scenario you described, stopping the move is
no less safe than entering the correct setpoint. If anything, stopping
is probably a little safer just because the user wouldn't have to think
about the correct setpoint and enter it; they could just stop the move.
But then you're saying that after commanding a stop, you can no longer
command a move to a new setpoint, ever? That seems broken.
Lewis
- Re: Delta Tau motor control problem Pearson, Matthew R.
- Fwd: Re: Delta Tau motor control problem Mark Davis
- Re: Delta Tau motor control problem J. Lewis Muir
Re: streamDevice 32-Bit ULONG endianess Dirk Zimoch
Re: Delta Tau motor control problem [email protected]
<2018>
<2018>
ANJ, 06 Aug 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
