1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Delta Tau motor control problem
To: Kevin Peterson <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 6 Aug 2018 12:03:09 +0000
Hi Kevin,
re using generic EPICS records. That is what I have done in the pmac driver by providing :DirectDemand PV (which is linked to a busy record that clears when the motor is done moving).
However, I felt that this was a bit messy, it was a breaking change to the interface and is a one off for our specific controller. A 'dumb' motor record mode would support all intelligent controllers and not require changes to the  software layers above.
Cheers,
giles.
Sent: 03 August 2018 17:32:11
To: Knap, Giles (DLSLtd,RAL,LSCI); Torsten Bögershausen; [email protected]
On 08/03/2018 08:26 AM, [email protected] wrote:
> For 'dumb mode' I would like the motor record to always send the commands that the user requests and only send those commands.
You aren't required to use the motor record to communicate with model 3
asyn motor drivers.  It is possible to use generic EPICS records with
asyn device support to access the various asyn motor parameters, which
would effectively be a 'dumb mode'.
Kevin
Re: Delta Tau motor control problem Kevin Peterson
Fwd: Re: Delta Tau motor control problem Mark Davis
Re: Re: Delta Tau motor control problem [email protected]
Re: Delta Tau motor control problem Torsten Bögershausen
Prev: Re: Delta Tau motor control problem Mark Davis
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Delta Tau motor control problem Kevin Peterson
Next: Re: Delta Tau motor control problem Kevin Peterson
ANJ, 08 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
