1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbGetPdbAddrFromLink dropped from 3.15 again
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Mon, 6 Aug 2018 09:15:59 -0700
On 08/04/2018 08:43 AM, Johnson, Andrew N. wrote:
> My assumption is that they’re wanting direct access to a large block of data without copying it. This should safe for DB links because of the IOC locking, as long as they aren’t copying pointers out of the dbAddr or using it outside of the locked record that is requesting it, so I could see us adding another API to the LSET that allows that for link types that can provide it.
> I would be wary of just handing out the dbAddr* pointer though, since the link could get changed without any notice, so I would like to add a little more enforcement. Some link types could even use this to provide access to their raw data buffers, so I’m wondering about an API like doLocked() where the caller gives us a function pointer which we call back with a dbAddr*.
My thinking has been something like:
> int dbGetPdbAddrFromLink(DBLINK *plink, DBADDR *pout);
which would be used like
> DBLINK *plink = ...;
> DBADDR addr;
> dbScanLock(plink->precord);
> if(dbGetPdbAddrFromLink(plink, &addr)==0) {
>    // do something with addr
Though this would look different in the context of an aSub function, the point
is that this avoids returning a pointer to the internal struct dbAddr by making
a copy.  This copy remains valid in perpetuity, although the assurance that both
records are covered by the same lock expires as soon as the source record is
unlocked.
Re: dbGetPdbAddrFromLink dropped from 3.15 again Andrew Johnson
dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
Prev: Re: Delta Tau motor control problem [email protected]
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
ANJ, 06 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
