1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbGetPdbAddrFromLink dropped from 3.15 again
To: Michael Davidsaver <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Mon, 6 Aug 2018 12:01:01 -0500
On 08/06/2018 11:15 AM, Michael Davidsaver wrote:
> On 08/04/2018 08:43 AM, Johnson, Andrew N. wrote:
>> I would be wary of just handing out the dbAddr* pointer though,
>> since the link could get changed without any notice, so I would
>> like to add a little more enforcement. Some link types could even
>> use this to provide access to their raw data buffers, so I’m
>> wondering about an API like doLocked() where the caller gives us a
>> function pointer which we call back with a dbAddr*.
> My thinking has been something like:
>> int dbGetPdbAddrFromLink(DBLINK *plink, DBADDR *pout);
> which would be used like
>> DBLINK *plink = ...;
>> DBADDR addr;
>> dbScanLock(plink->precord);
>> if(dbGetPdbAddrFromLink(plink, &addr)==0) {
>>    // do something with addr
> Though this would look different in the context of an aSub function,
> the point is that this avoids returning a pointer to the internal
> struct dbAddr by making a copy.  This copy remains valid in
> perpetuity, although the assurance that both records are covered by
> the same lock expires as soon as the source record is unlocked.
I don't believe it's legal to call any current dbLink.h function unless
you're already holding the lock for the record that owns that link, so
IMO your dbScanLock() should be superfluous.
Copying a dbAddr also copies its pfield member pointer. If the target
field of the link is using double-buffering that pointer isn't going to
be valid after the next buffer-switch, but your API doesn't indicate that.
That's why I'd prefer to have the user provide a callback function; it
should be obvious that the information provided is only valid for the
duration of the call (we can also avoid making a copy of the dbAddr):
typedef long (*dbLinkDbAddrCallback)(const dbAddr *paddr, void *priv);
long dbLinkDoDbAddr(struct link *plink, dbLinkDbAddrCallback rtn,
        void *priv);
This would call a new lset routine which only DB links would implement;
other link types would just return an error (unless they are willing to
give out access to their local buffer for the link data, in which case
they could create a dbAddr for that buffer).
In dbDbLink.c the implementation is just:
static long doDbAddr(struct link *plink, dbLinkDbAddrCallback rtn,
        void *priv)
    DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
    return rtn(paddr, priv);
Till, nothing more is likely to happen on this topic without your
feedback, would this API be sufficient to implement what you need?
- Andrew
Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
Prev: Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
Next: Re: Delta Tau motor control problem Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
ANJ, 06 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
