1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Problems with soft motors
Date: Mon, 10 Sep 2018 08:59:12 +0100
On 09/09/2018 06:26 PM, Mark Rivers wrote:
> So it copies the initial value to plink->text, rather than plink->value.constantStr, where the soft motor device support was expecting to find it.  In both cases it sets plink->type to CONSTANT.  Presumably the link type may get changed later to PV_LINK, CA_LINK, or DB_LINK when it is parsed.
cf. dbInitRecordLinks().  If you want to be notified after this happens use initHookAfterInitDatabase.
This comes after initHookAfterCaLinkInit so the dbCa worker has been started as well.
Were it me, I would defer all of this until initHookAfterIocRunning as I don't think there is any
reason it has to happen earlier, when the state of the IOC is less well defined.
From what I can see, the use of a worker thread here is to avoid having to deal with
swapping around libca contexts.  Complications arise because this worker is allowed to
run concurrently with parts of iocInit() which don't expect concurrency.
If you won't/can't wait for initHookAfterIocRunning, then imo. either get rid of
the worker, or have the main thread wait for the worker to finish processing
the soft_motor_list list.
> I understand that plink->value.constantStr should only be used if plink->type==CONSTANT, but is there a chance that this change is going to break other code that was relying on the previous behavior?
Historically Base has exposed a lot of structures and functions which
were not really intended/expected to be public APIs.  This makes
maintaining or using Base all the more difficult as it isn't clear what
was intended to be public API vs. what has become defacto public over
the years.  Some breakage is inevitable when attempting to bring some
order to this chaos.
Problems with soft motors Mark Rivers
Re: Problems with soft motors Mooney, Tim M.
Re: Problems with soft motors Andrew Johnson
Re: Problems with soft motors Michael Davidsaver
RE: Problems with soft motors Mark Rivers
Prev: RE: Problems with soft motors Mark Rivers
Next: Problem with 7.0.1.1 static built pvget Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: RE: Problems with soft motors Mark Rivers
ANJ, 10 Sep 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
