1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Re: ArchiveEngine
To: Shen, Guobao <[email protected]>, tech-talk <[email protected]>
Date: Wed, 12 Sep 2018 12:51:09 +0800
hi,
I run the quickstart.sh of archive appliance, try to archive a PV as "rootHost:ai2" from testApp in the same machine. but at web page side, it shows the pv can't be archived, not connected.
From the same shell, I can caget the value.
following is the message from starting the Archive appliance:
SRCDIR=/home/geyang/AA
DATADIR=/home/geyang/AA
Using org.epics.archiverappliance.config.persistence.InMemoryPersistence as the persistence layer
/home/geyang/AA/quickstart_tomcat
total 4
drwxrwxr-x 9 geyang geyang 4096 Sep 12 00:38 apache-tomcat-7.0.90
Using 64 bit versions of libraries
Starting in the foreground...
Using CATALINA_BASE:   /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90
Using CATALINA_HOME:   /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90
Using CATALINA_TMPDIR: /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/temp
Using JRE_HOME:        /usr/local/jdk1.8.0_181/jre
Using CLASSPATH:       /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/bin/bootstrap.jar:/home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/bin/tomcat-juli.jar
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=128M; support was removed in 8.0
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: apache-tomcat-7.0.90/webapps/engine/WEB-INF/lib/native/linux-x86_64:/usr/local/lib:/usr/lib:/usr/X11R6/lib:/usr/local/epics/r3.14.12.5/base/lib/linux-x86_64:/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64:/usr/local/epics/r3.14.12.5/extensions/src/epicsqt/framework/designer:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Sep 12, 2018 12:38:01 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-17665"]
Sep 12, 2018 12:38:01 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 359 ms
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 12, 2018 12:38:01 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.90
Sep 12, 2018 12:38:01 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt.war
Sep 12, 2018 12:38:03 AM org.apache.catalina.startup.TldConfig execute
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
0    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_SNAPSHOT_14-June-2018T10-14-31
1    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
5    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
6    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt/WEB-INF/classes/archappl.properties
7    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt/WEB-INF/classes/archappl.properties
38   [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaMgmtService <init>
INFO: Creating an instance of PvaMgmtService
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaServlet lambda$init$0
INFO: pool-1-thread-1
pvAccess Server v5.1.0-SNAPSHOT
CLASS   : org.epics.pvaccess.server.impl.remote.ServerContextImpl
VERSION : pvAccess Server v5.1.0-SNAPSHOT
PROVIDER_NAMES : rpcService
BEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : true
BEACON_PERIOD : 15.0
BROADCAST_PORT : 5076
SERVER_PORT : 5075
RCV_BUFFER_SIZE : 16384
IGNORE_ADDR_LIST:
STATE : INITIALIZED
Sep 12, 2018 12:38:03 AM org.epics.archiverappliance.mgmt.pva.PvaServlet init
INFO: 2018-09-12T00:38:03.630-04:00[America/New_York]pvaMgmtService is operational.
Sep 12, 2018 12:38:03 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/mgmt.war has finished in 1,857 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine.war
Sep 12, 2018 12:38:05 AM org.apache.catalina.startup.TldConfig execute
1    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_SNAPSHOT_14-June-2018T10-14-31
4    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
4    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine/WEB-INF/classes/archappl.properties
4    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine/WEB-INF/classes/archappl.properties
6    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.engine.pv.EngineContext  - Creating 10 command threads as specified by org.epics.archiverappliance.engine.epics.commandThreadCount in archappl.properties
16   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA/CAJ prop from archappl.properties is true
20   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
<context class="com.cosylab.epics.caj.CAJContext">
  <preemptive_callback>true</preemptive_callback>
  <addr_list>192.168.1.112:5064 192.168.1.122:5064</addr_list>
  <auto_addr_list>false</auto_addr_list>
  <connection_timeout>30.0</connection_timeout>
  <beacon_period>30.0</beacon_period>
  <repeater_port>5065</repeater_port>
  <server_port>5064</server_port>
  <max_array_bytes>30.0</max_array_bytes>
  <event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
</context>
31   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA/CAJ prop from archappl.properties is true
36   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
26   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA/CAJ prop from archappl.properties is true
19   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA/CAJ prop from archappl.properties is true
40   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
41   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
39   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
38   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
</context>
32   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA/CAJ prop from archappl.properties is true
31   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
</context>
46   [JCA Command Thread] INFO  config.org.epics.archiverappliance.engine.epics.JCAConfigGen  - JCA Configuration:
</context>
109  [localhost-startStop-1] INFO  config.org.epics.archiverappliance.engine.pv.EngineContext  - Creating 1 scan threads as specified by org.epics.archiverappliance.engine.epics.scanThreadCount in archappl.properties
182  [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:05 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/engine.war has finished in 1,957 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl.war
Sep 12, 2018 12:38:06 AM org.apache.catalina.startup.TldConfig execute
3    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://localhost:17665/mgmt/bpl
3    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl/WEB-INF/classes/archappl.properties
3    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl/WEB-INF/classes/archappl.properties
5    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:07 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/etl.war has finished in 1,421 ms
INFO: Deploying web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval.war
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.TldConfig execute
3    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties from the webapp classpath /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval/WEB-INF/classes/archappl.properties
3    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval/WEB-INF/classes/archappl.properties
4    [localhost-startStop-1] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
Sep 12, 2018 12:38:08 AM org.epics.pvaccess.server.impl.remote.tcp.BlockingTCPAcceptor initialize
INFO: Configured TCP port 5075 is unavailable, trying to assign it dynamically.
INFO: Using dynamically assigned TCP port 34845.
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalService <init>
INFO: Creating an instance of PvaDataRetrievalService
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet init
INFO: 2018-09-12T00:38:08.444-04:00[America/New_York]pvaDataRetrievalService is operational.
Sep 12, 2018 12:38:08 AM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet lambda$init$0
INFO: pool-13-thread-1
BEACON_ADDR_LIST :
SERVER_PORT : 34845
IGNORE_ADDR_LIST:
STATE : INITIALIZED
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/retrieval.war has finished in 1,422 ms
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/ROOT
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/ROOT has finished in 22 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/docs
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/docs has finished in 17 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/examples
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/examples has finished in 103 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/host-manager
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/host-manager has finished in 75 ms
INFO: Deploying web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/manager
INFO: Deployment of web application directory /home/geyang/AA/quickstart_tomcat/apache-tomcat-7.0.90/webapps/manager has finished in 24 ms
Sep 12, 2018 12:38:08 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-17665"]
Sep 12, 2018 12:38:08 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6953 ms
10040 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for MGMT
10041 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Initializing the MGMT webapp's clustering
10290 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Setting my cluster port base to 16670 and using interface 127.0.0.1
11080 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading PVTypeInfo from persistence
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 0 PVs from persistence into cluster
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading aliases from persistence
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 0 aliases from persistence into cluster
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archive requests from persistence
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 0 archive pv requests from persistence into cluster
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading external servers from persistence
11081 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading external servers from persistence
11087 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp MGMT
11087 [Startup executor] INFO  config.org.epics.archiverappliance.mgmt.MgmtPostStartup  - Finished post startup for the mgmt webapp
12382 [http-bio-17665-exec-1] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from ENGINE
10517 [http-bio-17665-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for ENGINE
10518 [http-bio-17665-exec-2] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Initializing a non-mgmt webapp's clustering
10579 [http-bio-17665-exec-2] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - ENGINE connecting as a native client to 127.0.0.1:16670
10905 [http-bio-17665-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp ENGINE
13679 [http-bio-17665-exec-3] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from ETL
10132 [http-bio-17665-exec-4] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for ETL
10134 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Initializing a non-mgmt webapp's clustering
10171 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - ETL connecting as a native client to 127.0.0.1:16670
11886 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Start archiving PVs from persistence.
11895 [Startup executor] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Started 0 PVs from persistence.
10543 [http-bio-17665-exec-4] INFO  config.org.epics.archiverappliance.etl.common.PBThreeTierETLPVLookup  - Beginning ETL post startup; scheduling the configServiceSyncThread to keep the local ETL lifetimeId2PVName2LookupItem in sync
10543 [http-bio-17665-exec-4] DEBUG config.org.epics.archiverappliance.etl.common.PBThreeTierETLPVLookup  - Done initializing ETL post startup.
10583 [http-bio-17665-exec-4] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp ETL
15058 [http-bio-17665-exec-6] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from RETRIEVAL
10130 [http-bio-17665-exec-7] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
10132 [http-bio-17665-exec-7] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - Initializing a non-mgmt webapp's clustering
10169 [http-bio-17665-exec-7] DEBUG config.org.epics.archiverappliance.config.DefaultConfigService  - RETRIEVAL connecting as a native client to 127.0.0.1:16670
10514 [http-bio-17665-exec-7] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
15451 [http-bio-17665-exec-6] INFO  config.org.epics.archiverappliance.mgmt.MgmtRuntimeState  - All components in this appliance have started up. We should be ready to start accepting UI requests
Best wishes
Geyang 2018-09-12
##############on 2018-09-11, [email protected] wrote:###############
Hi Geyang,
By meaning ArchiverEngine, I guess you are referring to Archiver Appliance?
If yes, you can simply download the pre-built binary from
https://github.com/slacmshankar/epicsarchiverap/releases/
There is a Quick Start how to run it on RHEL/CentOS for your testing purpose.
https://slacmshankar.github.io/epicsarchiver_docs/quickstart.html
Once you get your data archived, you can easily configure CS-S, and browse your history data.
You do not have to compile it yourself.
The answer might be different if you want to use RDB based archiver.
Guobao
From: <[email protected]> on behalf of Silver <[email protected]>
Date: Tuesday, September 11, 2018 at 5:46 AM
To: Tech-Talk <[email protected]>
Subject: ArchiveEngine
hi,
I downloaded a pre-compiled version of CSS from https://ics-web.sns.ornl.gov/css/. But I can't find where is ArchiveEngine executable file. Need I download the source code from github and compile it to get ArchiveEngine file?  My system is CENTOS7.
Thanks a lot for your help.
Best wishes
Geyang 2018-09-11
ArchiveEngine Silver
Re: ArchiveEngine Shen, Guobao
Prev: 回复:Re: No reply from device using asyn+streamdevice fatimah1129
Next: Re: Re: ArchiveEngine Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Re: Re: ArchiveEngine Silver
Next: Re: ArchiveEngine Shen, Guobao
ANJ, 12 Sep 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
