hi, Hartman: I download the file from URL as your suggestions, but how to configure the database, is there some documents? I only find some informations on http://cs-studio.sourceforge.net/docbook/ch11.html#sec_archive_config_tool. and there is a example file in CSS source code \cs-studio-master\applications\archive\archive-plugins\org.csstudio.archive.engine\plugin_customization.ini Are there any hints? Thanks a lot. by using it, there is some messages: 2018-09-12 02:58:32.662 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix pva provided by pva in org.csstudio.vtype.pv 2018-09-12 02:58:32.715 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix ca provided by ca in org.csstudio.vtype.pv 2018-09-12 02:58:32.716 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix ca provided by epics in org.csstudio.vtype.pv 2018-09-12 02:58:32.716 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix loc provided by loc in org.csstudio.vtype.pv 2018-09-12 02:58:32.717 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix sim provided by sim in org.csstudio.vtype.pv 2018-09-12 02:58:32.718 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - PV prefix mqtt provided by mqtt in org.csstudio.vtype.pv 2018-09-12 02:58:32.719 CONFIG [Thread 1] org.csstudio.vtype.pv.PVPlugin (start) - Default PV type ca 2018-09-12 02:58:32.721 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Archive Engine 4.0.0.201808301035 2018-09-12 02:58:32.810:INFO::main: Logging initialized @785ms to org.eclipse.jetty.util.log.StdErrLog 2018-09-12 02:58:33.018:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0 2018-09-12 02:58:33.018:INFO:oejs.session:main: No SessionScavenger set, using defaults 2018-09-12 02:58:33.019:INFO:oejs.session:main: Scavenging every 600000ms 2018-09-12 02:58:33.111 INFO [Thread 1] org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP Server on http://localhost:4812/main 2018-09-12 02:58:33.112 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Reading configuration '../archive-config-4.5.0/engineconfig' Loading class `com.mysql.jdbc.Driver'. This is deprecated. The new driver class is `com.mysql.cj.jdbc.Driver'. The driver is automatically registered via the SPI and manual loading of the driver class is generally unnecessary. 2018-09-12 02:58:33.150 SEVERE [Thread 1] org.csstudio.archive.engine.Application (start) - Cannot read configuration org.eclipse.core.runtime.CoreException: Plug-in "org.csstudio.archive.config.rdb" was unable to instantiate class "org.csstudio.archive.config.rdb.RDBArchiveConfig". at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.csstudio.archive.config.ArchiveConfigFactory.getArchiveConfig(ArchiveConfigFactory.java:37) at org.csstudio.archive.engine.Application.start(Application.java:220) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590) at org.eclipse.equinox.launcher.Main.run(Main.java:1499) at org.eclipse.equinox.launcher.Main.main(Main.java:1472) Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://localhost/archive?rewriteBatchedStatements=true at java.sql.DriverManager.getConnection(DriverManager.java:689) at java.sql.DriverManager.getConnection(DriverManager.java:208) at org.csstudio.platform.utility.rdb.internal.MySQL_RDB.connect(MySQL_RDB.java:63) at org.csstudio.platform.utility.rdb.RDBUtil.<init>(RDBUtil.java:179) at org.csstudio.platform.utility.rdb.RDBUtil.connect(RDBUtil.java:143) at org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:82) at org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:68) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at java.lang.Class.newInstance(Class.java:442) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) ... 18 more 2018-09-12 02:58:33.175:INFO:oejs.session:Framework stop: Stopped scavenging Best wishes Geyang 2018-09-12 ##############on 2018-09-12, [email protected] wrote:###############
ANJ, 12 Sep 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
