Try building everything static.
I had the exact same issue with an Oryx camera on Ubuntu 18 with the very latest Spinnaker SDK. AD did not detect any cameras while the vendor software did. But the static build worked, no idea why. The exact
same code fragments are used to initialize and detect the camera as is used in the example programs.
Hi all,
I’m struggling to get an IOC to connect to my BlackFly S camera which uses Spinnaker software. I’m using the HEAD revision of areaDetector with ADCore, ADSupport and ADSpinnaker from the GitHub.
I’ve managed to build all components but when I start the IOC, it fails to connect to the camera:
ADSpinnakerConfig("SP1", 18260782, 0x1, 0)
2018/09/19 14:48:27.180 ADSpinnaker:connectCamera: no cameras found
2018/09/19 14:48:27.180 ADSpinnaker:ADSpinnaker: camera connection failed (3)
Number of cameras detected: 0
I can see the camera using arv-tool-0.4 from aravisGigE component and list it’s feature without any problems.
Here’s my setup, as per documentation:
Ubuntu 16.04
GLIBC 2.23
GLIBCXX 3.4.21
GCC 5.4
Has anyone managed to get the IOC to talk to BlackFly S, model: BFS-PGE-16S2M-CS?
Andraz Pozar
Controls Engineer
Australian Synchrotron
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and
may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have
received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
