1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions about install
To: Maren Purves <[email protected]>
Date: Thu, 11 Oct 2018 16:12:51 +0000
Hi Maren,
On Oct 10, 2018, at 4:12 PM, Maren Purves <[email protected]> wrote:
should I start over with 3.15.6? - I started with 3.15.5 some
time earlier this year because it was labeled as the latest
stable release (little did I know that a bunch of other upgrades
in other areas would take a lot longer than anticipated - you
know how these things go).
The functional differences between 3.15.5 and 3.15.6 (including a number of changes pulled from the 3.14 branch) are described in the Release Notes available at https://epics.anl.gov/base/R3-15/6-docs/RELEASE_NOTES.html plus there were a number of bug fixes that didn’t get added to that document (the list is available at https://launchpad.net/epics-base/3.15/3.15.6 towards the bottom of the page should you wish to peruse it). The new stuff is mostly in the “nice to have” category in that they make it easier to do certain things and fix a few gotcha’s. I don’t know how much rework you would have to do, but there are almost 2 years of updates included so I would recommend using the latest if you can afford to do so.
HTH,
- Andrew
Re: Questions about install Maren Purves
Questions about install Lucock, Richard M
Re: Questions about install Jeong Han Lee
Re: Questions about install Lucock, Richard M
Re: Questions about install Johnson, Andrew N.
Prev: CAS / PCAS documentation Dr. Bastian Löher
Next: Re: Questions about install Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Questions about install Maren Purves
ANJ, 11 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
