1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Current Source / Power supply suggestion
To: [email protected]
Date: Wed, 7 Nov 2018 09:26:18 -0800
Dear Nilson,
I have been using peltier drivers from Meerstetter (https://www.meerstetter.ch/shop/tec-controllers/tec-1122-detail) and have been very happy with their performance.
An EPICS driver is available here: https://github.com/djvine/TEC1122
Best,
David
> Sent: Wednesday, November 7, 2018 6:49 AM
> To: Tech-talk
> Subject: Current Source / Power supply suggestion
> Dear All,
> I am developing a temperature control solution based on peltier
> elements. The PID loop will control the current on the peltier elements
> based on the target temperature.
> What I am really looking for are suggestions for remote control linear
> DC Current source (0-5A, >300W) or Power supply with available EPICS
> drivers.
> Any information will be truly appreciated. (Bonus for being easily
> available in europe)
> Thank you.
> Best regards,
> Nilson Pereira
Best regards,
David Vine
(925) 326 7503
http://www.Sigray.com
This e-mail and any attachments are provided for the sole use of the intended recipient(s), and may contain information that is confidential, privileged, proprietary or otherwise protected by law. If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy, forward or otherwise disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and delete the original message from your mail system. Thank you.
PNG image
Prev: Re: Record referencing inside device support Mooney, Tim M. via Tech-talk
Next: RE: Record referencing inside device support Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Current Source / Power supply suggestion Heinz Junkes
Next: Job openings at Diamond Light Source [email protected]
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
