1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record referencing inside device support
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: Allan Serra Braga Bugyi <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 7 Nov 2018 17:20:43 +0000
Hi Allan,
If you look at some existing device-support code (for example,  base-3.15.4/src/std/dev/devAaoSoft.c) you'll see that routines in that file are called with a pointer to the record struct.  You might want to look at this presentation from a recent EPICS class:
https://epics.anl.gov/docs/APS2015/01-EPICS-Device-Support.pdf
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, November 7, 2018 11:10:54 AM
To: Mooney, Tim M.; [email protected]
Hi Tim,
My limited comprehension of EPICS building facility may be blurring my understanding of the problem. In my comprehension, EPICS building facility generates header files from .db files, right? So, each record will be an "instance" of the accordingly struct. However, this happens during compilation time. Where would it be possible to know the structs' names for referencing inside device support?
Best,
Allan S. B. Bugyi
Technology Development Analyst
[email protected]
(+55 19) 3512-3520
SOL/Beamline Software Group
Brazilian Synchrotron Ligh
t Laboratory (LNLS)
Center of Research in Energy and Materials (CNPEM
http://lnls.cnpem.br
De: Mooney, Tim M. <[email protected]>
Enviado: quarta-feira, 7 de novembro de 2018 14:53:19
Para: Allan Serra Braga Bugyi; [email protected]
Assunto: Re: Record referencing inside device support
Hi Allan,
My first thought would be to write device support for the record.  Device support has access to the record structure.
From: [email protected] <[email protected]> on behalf of Allan Serra Braga Bugyi <[email protected]>
Sent: Wednesday, November 7, 2018 10:47:25 AM
To: [email protected]
Subject: Record referencing inside device support
Hello all,
I have the need to access the record support structs inside my C code. What I want is to be able to access the records' fields to pass them as parameters to some functions. These functions are inside a dynamic library .so from the manufacturer. Any idea or workaround?
Many thanks!
Allan S. B. Bugyi
[email protected]
(+55 19) 3512-3520
t Laboratory (LNLS)
Record referencing inside device support Allan Serra Braga Bugyi
Re: Record referencing inside device support Mooney, Tim M. via Tech-talk
Re: Record referencing inside device support Allan Serra Braga Bugyi
Prev: FWD: Record referencing inside device support Allan Serra Braga Bugyi
Next: Re: Current Source / Power supply suggestion David Vine
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record referencing inside device support Allan Serra Braga Bugyi
Next: Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
